12-26-2015, 02:33 PM
Can any one steer me in the right direction to where to get new front brake lines made? It seems they are all one piece from the front master cylinder to the calipers. I would like to add length to them.
Front brake Lines
12-29-2015, 02:45 AM
Spiegler USA can make custom lines.
https://spieglerusa.com/brakes/brake-lin...lines.html Galfer USA site says they also make custom lines but web page not complete like the Spiegler site. Aloha, Huladog Sent from my iPad using Tapatalk
12-29-2015, 04:06 AM
(12-29-2015, 02:45 AM)Huladog_imp Wrote: Spiegler USA can make custom lines. I haven't checked, but I believe Galfer has an order sheet you can download to specify what you want/need and then fax back to them. I have Spiegler lines on my CBR and they are fantastic. Also, Spiegler has a kit for the CB1100: http://www.sportbiketrackgear.com/spiegl...mlar-orig/ They also have for the rear and clutch.
12-29-2015, 08:47 AM
You can just phone up either and talk to a tech.
12-29-2015, 09:49 AM
I had longer lines done at a local shop. The challenge was that they couldn't get the "one into two" setup like the original because the lines are pretty much sealed to that Y splitter in the middle. So I now have two lines running from the master cylinder to the brakes. Works fine, but not as elegant. I hope you can find a better solution.
12-29-2015, 11:49 AM
Every custom line maker told me 2 years ago that y splitter was not possible, so had to do the two lines from master.
2014 CB1100 DLX 2013 CB1100 Std 1990 BMW K75 RT
01-02-2016, 12:52 AM
Brake line splitters are available:
http://www.dimecitycycles.com/vintage-ca...d7024.html Buy universal brake line that come in a zillion lengths and the associated fittings: [url=http://www.jpcycles.com/search/search?Ntt=brake+lines&N=28012733&Ntk=All]http://www.jpcycles.com/search/search?Nt...33&Ntk=All
01-02-2016, 01:04 AM
Cool. Wish I'd have seen that a few months ago. Oh well. This setup is getting the job done.
01-02-2016, 09:17 AM
How did you come off the front master cylinder with two brake lines (one for each side)??
01-02-2016, 01:17 PM
(01-02-2016, 09:17 AM)wiredgeorge_imp Wrote: How did you come off the front master cylinder with two brake lines (one for each side)?? They make banjo (?) end thingies that can be stacked, so there are two coming off the master cylinder. As I say, not elegant, but it works. I'll take a photo tomorrow when I'm futzing with the throttle cables. |
« Next Oldest | Next Newest »
| Front ABS Brake"Rain Stick" noise | bflint | 3 | 475 |
07-12-2024, 08:36 AM Last Post: Race_ca1 |
| Front brake inconsistent resistance | ChiefJP_imp | 16 | 1,457 |
06-14-2023, 07:46 AM Last Post: bvictory_imp |
| Sqealing front brake | thop_imp | 10 | 1,042 |
06-14-2023, 07:34 AM Last Post: bvictory_imp |
| Front brake lever ROCK hard | ichiban_imp | 37 | 3,973 |
02-10-2023, 10:54 PM Last Post: Lord Popgun |
| FRONT BRAKE TIGHTER | omnimj_imp | 2 | 278 |
09-08-2022, 02:43 AM Last Post: 1985CB450_imp |
| Oil cooler lines pitting | DBM_imp | 6 | 639 |
10-19-2021, 09:05 AM Last Post: DBM_imp |
| Front brake.... pulsating??? | mattmcuomo@yahoo.com | 12 | 803 |
05-11-2020, 03:51 AM Last Post: max |
| Front Brake Drag | 2017EX_imp | 16 | 992 |
04-10-2020, 01:22 AM Last Post: dave |
| Correct part number for front brake pads | Frulk_imp | 7 | 660 |
02-18-2020, 08:06 AM Last Post: iamheero_imp |
| Replaced front brake pads for 1st time at 20K miles | Frulk_imp | 15 | 1,081 |
01-04-2020, 02:15 AM Last Post: Bheezy27403_imp |
