Oil cooler lines pitting
I saw some small rust pits on the chrome oil cooler lines. I am wondering if a problem could occur from these pits causing a leak.
Maybe unlikely, but ... pictures speak volume. Let the Forum masses see?
(10-15-2021, 08:03 AM)DBM_imp Wrote: I saw some small rust pits on the chrome oil cooler lines. I am wondering if a problem could occur from these pits causing a leak.
I occasionally get some in the same place but it is generally just a little bit of surface rust which easily comes away on a clean. A bit of FS365 or similar all around the engine does help in this respect.
Yes, some modern chrome polish/paste will make fast work of surface rust pitting and protect the region in the future.
I find ACF50 is very good at stopping corrosion.
https://www.mslmagazine.co.uk/tested-acf...on-review/
Try to scrub with aluminium foil. If it's surface dirt/rust it will come off, and th aliminium won't scratch chrome or stainless
(10-16-2021, 07:54 PM)jtopiso_imp Wrote: Try to scrub with aluminium foil. If it's surface dirt/rust it will come off, and th aliminium won't scratch chrome or stainless
Thanks for the tip
(10-16-2021, 06:04 AM)GoldOxide_imp Wrote: Yes, some modern chrome polish/paste will make fast work of surface rust pitting and protect the region in the future.
I will try this and report back. I have a tube of SemiChrome paste
I will try this and report back. I have a tube of SemiChrome paste.
Photo Oil cooler inspection max 11 1,276 05-26-2025, 03:12 PM
  Chrome Pitting on Fork Tubes dave 11 822 09-07-2018, 11:22 PM
Last Post: SportsterDoc
  ss brake lines jimgl3_imp 8 603 05-20-2018, 08:44 PM
Last Post: jimgl3_imp
  Oil cooler LongRanger_imp 104 7,143 02-10-2017, 02:12 AM
Last Post: Desert viper_imp
  Oil lines Jay-g_imp 2 241 09-16-2016, 01:20 AM
Last Post: Jay-g_imp
  Front brake Lines Swartzracer_imp 10 754 01-02-2016, 02:07 PM
Last Post: wiredgeorge_imp
  OIL COOLER PAINT BLISTERING aussie59_imp 15 1,123 07-23-2015, 09:19 PM
  Braided lines - U.S. source ncgeezer_imp 6 422 04-22-2014, 09:51 AM
Last Post: thessler3_imp
  Braided Lines cbfan_imp 7 559 04-08-2014, 12:41 AM
Last Post: Red Mist_imp
