Engine Noise/Pinging?
So I have ridden about 2300 miles on the cb and it seems to have developed a pinging at idle that was not there after the first service. I noticed that it does not come along until the engine is warm or I ride on a warmer day. Sometimes I can get it to come around by accelerating pretty hard and shifting at around 4k rpm. Is this normal?
You are probably just noticing the fuel injectors making noise
It's not impossible, but it's challenging to make an engine ping at no-load idle. Try holding a long screwdriver or socket extension to your ear while touching it to various parts of the engine, i.e., the fuel injectors.
I'll do that and see if I can pinpoint it. I tend to worry a lot because the 1100 is my only running vehicle for the moment. Thanks for the replies.
You will (or at least I do) notice slightly more valve-train noise at idle as your oil shears and thins out after some use, but I would probably agree with others that it's probably just the injectors you're hearing.
  Front wheel bearing noise? MagnaRider 20 1,646 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,061 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 921 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 443 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 973 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 572 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 672 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,610 03-18-2021, 01:22 AM
  Strange wizzing noise LoyalKhan664_imp 28 1,928 10-02-2020, 05:58 AM
  Ticking Pinging sound Maurice_imp 17 1,097 05-05-2020, 11:19 PM
Last Post: alprider
