Strange wizzing noise
Hi. I’m new here and I wanted to ask you guys a question. I’ve got an CB1100RS and I noticed a strange whizzing high pitched noise coming from the left hand side of the engine. I can hear it clearer if I spread the left leg. Did you guys notice it? Could it be the starter? Thanks
Or the alternator. Starter only makes a noise when its, you know, starting Wink
Welcome to the Forum!
LK644, now days you should keep legs tight together, 0.02 Tongue
Now seriously, can you submit a short video/sound clip?, so these members with good hearing can help you.
Beer
Thanks for the replies. It sounds like a dry gear or bearing. I’ll record a video. The leg seems to block the noise, You can only hear it when you move your leg out of the way.
Does it makes the noise when only the engine runs or only when in gear ? Easy to check when on centerstand .
Welcome to the forum, LK.
Only in gear. I was thinking about trying that. It intensifies as you accelerate.
(09-24-2020, 05:12 AM)Cormanus_imp Wrote: Welcome to the forum, LK.
(09-24-2020, 01:44 AM)LoyalKhan664_imp Wrote: Hi. I’m new here and I wanted to ask you guys a question. I’ve got an CB1100RS and I noticed a strange whizzing high pitched noise coming from the left hand side of the engine. I can hear it clearer if I spread the left leg. Did you guys notice it? Could it be the starter? Thanks
Hi, this may sound weird, but riding my 2013 CB home today after getting it inspected, I heard, for the first time, a high pitch, whizzing noise that seemed to be coming from the front of the engine. I have never heard it before, or on my 2017 EX. Going to ride it on Friday to see if I can pin-point where it is coming from.
Although the adjustment is on the right LK, maybe the gear lash adjuster needs attention.
Or maybe the cam chain tensioner? A member had problems with that, but I can't remember the sound it made.
I just noticed this should really be in the Mechanical section of the forum. A lot of members don't really look here and it would get a better response there.
I’ll put it on the centre stant today to try and replicate it. It’s like a metallic ball in a can you shake and as you rev it the frequency of the noise intensifies until it becomes a whizzing noise. I noticed at low rpm eg. 1200 you can notice the pause in between the rattles. Very weird. Maybe it’s meant to be there, my bike is under a year old.
  Front wheel bearing noise? MagnaRider 20 1,777 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,292 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 963 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 469 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 1,014 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 646 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 724 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,804 03-18-2021, 01:22 AM
  strange start pdedse 48 2,837 02-02-2020, 06:34 AM
  Unhealthy Engine Knock / Noise spakins_imp 33 1,807 01-30-2020, 01:22 AM
Last Post: max
