Fumoto Valve Fit Question
Does anyone have one of these? http://www.amazon.com/dp/B00HTV2N4E?psc=1
14mm drain plug, I like the easy access versions.
Next week I'm going to be getting a '14 base model and noticed the service interval for the oil changes is 2x what I'm used to, so I thought I'd throw a Fumoto valve on there to make it go a little quicker/cleaner. Does anyone have one on their bike? If so, was it a PITA to install? It seems like there's a little ridge near the drain bolt that may prevent it from fitting, but since I don't have the bike yet I can't say for sure.
I'd be concerned that the ball valve could somehow rotate itself open, or partially open, while riding...
You can get a version that's harder to open, and they can come with a clip-in cover for those so the valve is physically locked into place until you remove said clip.
An interesting gadget, but I'm old school and don't mind doing it the old fashioned way.
That said, I'm not so old school that I dismiss new ideas. If anyone gets one I would be interested in hearing how well it fits and works.
Didn't know there's a harder- to- open version...well that changes the picture for sure.
I may get one for my Husaberg dirt bike, which has a 10 hour oil change interval, or ~200-250 miles, ie, a full weekend's ride.
(04-13-2016, 01:32 AM)Rocky_imp Wrote: An interesting gadget, but I'm old school and don't mind doing it the old fashioned way.
I'll probably end up trying it out and if I do, I'll definitely document it for the forum. I don't really mind the 4,000mi interval, though it kinda stinks. Living in an apartment means anything I can do to make it easier is a big help.
I have one on my 2008 Land Cruiser. Its tucked up behind a skid plate so I have no worries of it becoming knocked open. But on the CB it would seem to stick down further than the plug and the raised area on the pan. I could see something getting caught on it.
I like the idea but would be worried it would stick down so far that going thru a pot hole or over a speed bump would damage it.
(04-13-2016, 09:42 AM)slolane_imp Wrote: I like the idea but would be worried it would stick down so far that going thru a pot hole or over a speed bump would damage it.
I'd second that too. I've hit the two little metal stalactites that hang down at the front of the oil pan by accident going over some particularly tall speed-bumps, I definitely wouldn't want anything important hanging down there that low.
I have one on my Toyota Tacoma and love it. Once it's on you don't have to worry about changing out crush washer and/or stripping threads. It's as simple as turning on a valve and letting the oil flow out. Also, there are different variations available based on ground clearance. Also, there's a little plastic safety clip that locks into place that prevents accidental opening of the valve.
All of that said, would I use it on my CB? Yes if I put on as many miles as some of you but my mileage is pretty low. Annual oil changes is about all I do so I will continue to do it the old fashioned way.
  Valve Adjustment Shims dave 13 735 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 646 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 875 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 978 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,101 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,577 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,482 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,687 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,877 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 662 07-08-2022, 03:41 AM
Last Post: 1973cb750
