Air filter
I am approaching 25,000 miles on my 14. Has anyone checked or replaced the oem air filter due to being dirty? At what mileage?
Has anyone taken it out, shot air thru it to clean it and put it back in?
I know some guys are up around 35-50,000 miles now.. PTero, Kenny, lola?
I pulled mine last night only to discover the prior owner had installed a K&N. It was immaculate (not dirty at all) but rather than reinstall it, I'm replacing it with an OEM filter. The K&N is posted for sale in the For Sale section here if anyone is interested. Back to your question, it certainly doesn't hurt to check it every 12k miles, but unless you ride in dusty conditions, I'm guessing it'll probably be clean and just need to be tapped out to remove the bugs.
I just checked mine about a week ago, 8,000 mi. Still looks new, I gave it a shot of air, a small bit of dust came out. I would say if you shine a light inside it and you see light through the filter it's good. That looks like a pricey air filter.
Ferret, I'm pretty sure Pterodactyl gave his a good clean out at some point and reported improved performance. I'm afraid I can't remember whether he posted about it on the forum or just told me.
(07-01-2016, 09:17 PM)The ferret_imp Wrote: I am approaching 25,000 miles on my 14. Has anyone checked or replaced the oem air filter due to being dirty? At what mileage?
I take mine out at every rear tire change, 10,000 mi or so. It doesn't seem to get as dirty as I would expect it to. It's a mile on dirt road out/in to our driveway. I blow air through it and along the outside and a little dust comes out, but not much.
Just completed a trip back from Pennsylvania last week. Total miles at 41,500.
Should we just replace it even though it "looks" clean?
I'm at 28,000 on my '13 and planning to finally install the new OEM I bought at 8,000 mi. Original was so clean at 8K and 16K, I've been kinda slow to get to it. Plan to this month, though. I figure 28-30K is plenty to justify an air filter, even if it's a bit spendy. Probably will change plugs on next valve check, too, just on principle. Might as well, if I have the tank off. Also, I have noticed a bit of a decrease in mpg, and these two maintenance items can't hurt.
I'm not one of those guys. I replace if needed and usually a little late lol
The Honda PGM-FI system will compensate for air filter performance somewhat. If the HO2S reports a biased rich mixture (for any reason including a restricted air filter) the bike's computer will adapt by narrowing the injector pulse width. This fuel adaptive strategy does have limitations though and air filters need to be replaced periodically.
I didn't need to replace it at 16K, I forgot to check it before my long trip since I was distracted by tracking down the correct rear sprocket. I will check it at 32K service this week. I plan to pick one up just in case when I get the oil filter.
Ferret, I clean the filter every 12000kms at the major service. Plus, if I ride dirt, then as soon as possible. I have never replaced the filter, preferring instead to clean it. I blow it out with compressed air (I have a compressor), tap it firmly rim first on to a table to dislodge crud and even use a vacuum cleaner with attached brush on the outer surface. You might be surprised how much dust, dirt, even small tar pellets and road grime you dislodge.
I'm doing mine in the next day or two along with some remaining service items. Plugs cleaned and valve clearances [url=http://cb1100forum.com/forum/showthread.php?tid=8882&pid=139671#pid139671%20]have been checked and the heat shield and electronics are back in place. I'm in no hurry as I've decided, after removing the fuel tank on at least four occasions, to follow the Service Manual recommendation and at last replace the fuel line damper connector and retainer. They are cheap, less than $20, so why not? They should arrive by courier in the next few days.
  Oil Filter dave 12 540 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,456 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,428 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,803 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,465 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,256 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 899 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,163 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,853 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,172 09-07-2021, 07:44 AM
