CB1100 2013/2014 REAR WHEEL INTERCHANGABLE?
I slid out on wet pavement on my 2014 CB1100 standard yesterday, Not a scratch on me thanks to my T-Rex racing crash bars. My rear wheel smacked the curb and got trashed. Is the wheel from the 2013 CB1100 (part no. 42650-MGC-305) interchangable with my 2014 wheel? My spoke pattern is different from the 2013 wheel I saw but all I care about is that the sprocket and axle hardware will interchange.
Umm....same wheels, just different colors.
I swapped out the original mag wheels from my 2011 - 2013 for the spoked wheels from the 2014. The fronts are identical and straight swap however the 2014 rear uses a thinner axle and as such the bike required some modification. Not sure if this is helpful but I'd suggest you also compare the other hardware including the axle, spacers, rear disc carrier and brake hose etc.
I'm converting my black 2014 Cb1100 to the spoke wheels, like the European model has. I got the spoke wheels thru Mr. T in Japan. Anyway, I'm going to have a nice stock rear wheel available for sale soon, probably at a very reasonable price. Can you wait, or do you need it right now? Let me know
PM sent. Thanks.
Hey, I switched internet providers and have a new email address, so I won't get the message you sent. Please send again to jgclp@mediacombb.net
  Front wheel bearing noise? MagnaRider 20 1,924 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 374 02-05-2026, 08:11 AM
Last Post: 1973cb750
  2014 DLX - rear ABS clunk kvdv_imp 11 982 12-14-2025, 10:29 AM
Last Post: Easynow
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,584 08-16-2025, 05:01 PM
Last Post: bflint
  CB11OO EX wheel rims sprint 6 693 02-26-2025, 06:16 AM
  CB1100 2013: what is the original chain relation? valkyrie_rider_imp 6 866 08-26-2024, 12:23 PM
Last Post: Randy B
  2014 rear wheel knocking noise dunebuggy_imp 7 979 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Oil change CB1100@2013: photos valkyrie_rider_imp 12 1,199 02-14-2024, 11:25 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 259 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 254 02-13-2024, 10:27 AM
