CB1100 2013: what is the original chain relation?
Gentlefolks
I'm looking to replace the chain + sprockets in my 2013 CB1100 and wanted to double check what is the *original* relation before ordering the parts.
At Sprocket Center (https://sprocketcenter.com/i-30498628-53...3-19.html) they have a kit that supposedly includes everything needed.
I just wanted to double check if the relations are correct: 18 Front, 39 Rear, X-ring (1400cc rated).
Is the above equivalent to the OEM chain/sprocket that Honda ships on the 2013 CB1100?
Checked the OEM on line parts stores; you have the correct sprocket sizes (F-18 T, R-39 T). The chain rating should be fine. There should be 120 links (stock length).
Good luck
@Razor: thanks a lot!
(08-21-2024, 07:38 PM)Razor_imp Wrote: Checked the OEM on line parts stores; you have the correct sprocket sizes (F-18 T, R-39 T). The chain rating should be fine. There should be 120 links (stock length).
Good luck
For a direct replacement on a 2013 staying with the 18/39 ratio, use a 530 sealed chain, 110 links.
Good luck
Honda says it's 120 links, Pauley.
CHAIN, DRIVE (DID50ZVM-120ZB) (DAIDO)
40540-MBR-003
Honda
Good luck
40540-MBR-003
Honda
40540-MBR-003
Honda
New chains come with 120 links, you cut off 10 for the standard setup. I've gone through 2 sets of chains and 18/39 sprockets, always 110 links.
Good luck
40540-MBR-003
Honda
40540-MBR-003
Honda
40540-MBR-003
Honda
Ahhh... OK. Didn't know that.
  Oil change CB1100@2013: photos valkyrie_rider_imp 12 1,102 02-14-2024, 11:25 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 243 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 238 02-13-2024, 10:27 AM
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 485 05-22-2023, 12:25 PM
  Short shocks for 2013 CB1100 Griz53_imp 2 388 03-23-2023, 11:38 AM
Last Post: Griz53_imp
  CB1100 chain stretched out already @ 3k? gretle_2.0 12 932 06-30-2022, 02:18 AM
  What replaces the original 180/80R18 Dunlop Sportmax D205 tires HondaFan_imp 16 1,168 03-27-2021, 05:47 AM
Last Post: j3gq_imp
  2013 cb1100 Left Directional Light wont cancel. M3-SRT8_imp 15 1,151 08-01-2020, 07:16 PM
Last Post: max
  How to adjust the front forks on a 2013 CB1100 and a 2017 CB1100EX. michael1954 13 967 02-28-2020, 07:56 AM
  Easier Pull Clutch? 2013 CB1100 Jeeves_imp 10 797 02-18-2020, 12:38 PM
