turn signal flasher
just replaced all four indicator lights with led - love the brightness and; hopefully, the longevity. But now the indicators flash faster - i am guessing less resistance. Anyone have a clever fix? a different flasher part number? thanks
Search will be your friend. Add resistors or replace flasher relay with digital unit.
Sent from my iPad using Tapatalk Pro
(06-01-2017, 12:45 PM)Elipten_imp Wrote: Search will be your friend. Add resistors or replace flasher relay with digital unit.
Thanks - thought that would be the answer - any suggestions on a digital delay unit - anyone?
As said, search is your friend: http://cb1100forum.com/forum/showthread....ht=flasher
You need the POSH unit.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,545 08-16-2025, 05:01 PM
Last Post: bflint
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 791 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 1,054 04-20-2023, 10:17 AM
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 563 12-08-2022, 09:24 PM
Last Post: leung_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 2,002 07-12-2022, 08:04 PM
Last Post: tommymck
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 646 01-31-2022, 09:53 AM
  2013 turn signal replacement RF(OEM) casey66_imp 17 1,348 01-15-2022, 01:31 AM
Last Post: Bazbro_imp
  Turn Signal Malfunction billyfinchapel_imp 5 579 05-04-2021, 01:51 PM
Last Post: billyfinchapel_imp
  rear signal assembly cj599_imp 14 1,029 03-19-2021, 08:14 AM
Last Post: cj599_imp
  Rear Turn Signal relocation paulw_imp 10 885 03-07-2021, 05:50 AM
