17 T front sprocket
I'm thinking about to replace the 18 teeth front sprocket by a 17.
For me, the original 18 makes a little bit too long transmission overall at my 2013 (5 gear). On typically small or 2 lane roads here, if I let it run, I'm almost only in the 2. gear.
I'm talking about canon carving, not highway (or Autobahn).
Has somebody else here the same feeling?
(01-15-2015, 12:17 AM)Django_imp Wrote: I'm thinking about to replace the 18 teeth front sprocket by a 17.
It all depends how fast your carving the canyon??? 2nd gear will get you in the power-band up to 75-80mph topping out at 85mph. Are you carving that fast??? Now if your taking it easy around 5-6K maybe something to think about.
My experience... http://cb1100forum.com/forum/showthread.php?tid=3586
Just be aware that when riding to the canyons, your engine will be running north of 3600 rpm at 60mph.
(01-18-2015, 03:22 PM)Bike #12_imp Wrote: My experience... http://cb1100forum.com/forum/showthread.php?tid=3586
Thank you very much for that link! Thumbs Up
Actually your experience encourages me, to go for a try of a 17 sprocket.
You are welcome Smile
i haven't been on the forums for a while but i just noticed your post and thought i'd chime in.
the 17t front sprocket was the best 20$ i spent on this bike. it is now smoother upshifting and downshifting, less jerky at lower speeds (i guess the engine likes running at a little more revs than i had been shifting/riding at) and actually has less buzz in the bars at highway speeds. in the end, the bike still hits the limiter before it stops pulling, and a change in fuel economy wasn't noticeable, so i don't see any negatives.
on a similar note, it also accelerates quicker now--anyone who has ever driven a stick shift car for something other than commuting will attest to this fact.
jt
17t was definitely best investment i have made. Wakes the bike up, much more lively. At 110km/h in 6th revs went from 3100 to 3250~ so no big deal in long run - in the lower gears the torque multiplication is much better - less lurching from gear to gear - nice harder launch - and you can really let the bike idle and ease the clutch out and it will pull away with no stall - when two up - full box - don't have to slip the clutch and that makes for a happier partner -
(02-03-2015, 04:26 AM)sochiro_imp Wrote: i haven't been on the forums for a while but i just noticed your post and thought i'd chime in.
jt
I found all of the above when I did the change on my 2016 - should have been the standard on the bike at the start
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,234 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,416 07-30-2024, 10:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 5,191 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,345 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,087 01-03-2022, 08:30 AM
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 4,819 03-07-2021, 09:32 PM
  Another chain and sprocket question bflint 20 1,764 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,898 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 590 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
  Chain & Sprocket Questions arse-onist_imp 12 1,049 08-14-2019, 09:39 PM
