Another Arrow issue lol, cant get baffle out
Hey everyone, im having issues pulling the baffle out of my arrow slip on. Knocked off the welded tab, pulled snap ring out, but for the life of me i cannot get the baffle out. I sprayed a little WD around the seams to help lube it up but it will not come out. It pops out a hair and will rotate but i just cant get it out. Anyone else experience this? Any suggestions? Thanks again!
(10-23-2017, 10:59 AM)greekcb_imp Wrote: Hey everyone, im having issues pulling the baffle out of my arrow slip on. Knocked off the welded tab, pulled snap ring out, but for the life of me i cannot get the baffle out. I sprayed a little WD around the seams to help lube it up but it will not come out. It pops out a hair and will rotate but i just cant get it out. Anyone else experience this? Any suggestions? Thanks again!
No such issue with my Staintune, but I did have issues with removing the baffles in some Hard Krome pipes, and the best way to wiggle them free was by sticking a broom stick or other wooden handle down the central core and walking the baffle out a hair at a time with a lateral, back and forth movement. If the central core of the Arrow baffle won't allow that, a smaller, appropriately sized dowel may be required.
Hope this helps!
Hope this helps!
Hope this helps!
Hey Gumby yes it did thanks! I used a 1.25 inch dowel rod , 4 footer. Lubed it up again and basically moved the dowel rod counterclockwise in the baffle hole and just held the exhaust pipe with the other hand to let the dowel rod have more of an affect. Did it for a couple minutes and didn't think it was working but then i noticed the lip of the baffle out slightly further than before. So i kept it up for a few more minutes and it finally gave. Man what a nice little workout. I just didn't expect this on a new pipe vs an old carboned up/rusted pipe. Anyway, cant ride because of the weather but i got the reaction i wanted starting it this time vs with the baffle in. Def has the tone i wanted. Cant wait to run it on street, thanks again!
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 549 01-30-2026, 02:16 PM
Last Post: JRD
  Valve Cover Baffle lining ? bflint 6 930 07-26-2025, 11:27 AM
Last Post: bflint
  Shifting issue Cormanus 31 2,282 05-15-2024, 12:59 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 466 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 287 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,338 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 683 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 369 11-27-2021, 07:11 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,100 07-19-2021, 08:28 AM
  starting issue jigs_imp 12 820 06-06-2021, 01:51 PM
Last Post: max
