indicator conversion
As my 2014 and 2017 have the indicator button on the bottom I decided to covert my 2013 to the same set up as it is more natural and safer to have them all the same.
It is a very easy and quick job , 15 to 20 minutes at the most.
I used my air compressor to get the grip of , very quick and no mess.
The ferret has done the same, except in reverse.
Good move.
[quote='Cormanus' pid='188975' dateline='1512680252']
Good move.
I did what ferret did.
Just curious, how did you use the air compressor to get the grip off? I've heard people mention that but never knew the technique
Sent from my SM-G950U using Tapatalk
(12-08-2017, 04:08 AM)dwcurton_imp Wrote: Just curious, how did you use the air compressor to get the grip off? I've heard people mention that but never knew the technique
Very easy ,use the fine point air needle (the one you use for blowing up footballs etc) put that needle under the grip and blow the air , just go around the grip and it will blow up away from the handle bar.
No need for screw driver and WD 40 and therefor no cleaning afterwards .
If you do not have the fine needle , they come in a set with other parts , very cheap at Walmart.
I just wedge the end of the air nozzle in there clamp my hand around it and shoot the air into it. Never used a needle. Blows it right off.
If you do not have the fine needle , they come in a set with other parts , very cheap at Walmart. Ok thanks! I've been thinking about changing grips recently. That technique will certainly help.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,522 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 681 04-18-2024, 03:01 AM
  Question re: 2017EX spoke rims tubeless conversion slmjim n Z1BEBE_imp 6 569 10-28-2023, 09:24 PM
Last Post: slmjim n Z1BEBE_imp
  Power source for oil indicator led norton1974_imp 1 276 12-31-2022, 10:07 AM
  Gear indicator Billie_imp 11 975 02-22-2022, 03:24 AM
Last Post: gswanson89_imp
  Service indicator - unleashed j3gq_imp 6 610 07-27-2021, 03:12 AM
  Rear indicator design problem Mixagon_imp 5 507 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
  Turn Indicator Switch question Scotty_imp 6 512 09-22-2020, 11:58 AM
  Gear shift indicator stuck on 4 bflint 39 2,625 03-11-2020, 02:46 AM
  Changing indicator lamps max 1 209 12-02-2018, 07:47 AM
