Gear indicator
Recently picked up a 2014 CB 1100, liking it a lot.
On occasion a negative symbol will appear when I'm down shifting, either when stopped or rolling to a stop. Manual says I'm down shifting improperly.
Any input?
(07-10-2020, 12:30 PM)Billie_imp Wrote: Recently picked up a 2014 CB 1100, liking it a lot.
Any input?
I have never seen that, probably some government mandated software if the bike predicts your having too much fun!!!!!!!!!!Banana
Any input?
The switch assembly is indicating that you are not in gear.
May want to clean the switch area, check switch connection and fasteners.
Otherwise, pretend it is a Harley and shift like you mean it.
Any input?
Thanks, I can do that.
The (-) appears when the shift drum isn't rotated completely with each gear change. This can be caused by not shifting carefully or it could be caused by external reason, like if the shift lever is physically binding on the pivot bolt.
More likely, the shift lever is not adjusted to your foot to allow a normal, comfortable range of motion. Sometimes wearing different shoes changes your footpeg-to-shift lever angle. The hand and foot control angles can make a big difference in your comfort and to function.
I have seen it a few times too.
Not gonna worry about it.
http://cb1100forum.com/forum/showthread....+indicator
Shift technique is more than just oofing it up and stomping it down. When I first started riding, lo these many moons ago, I'd miss a lot of shifts, up and down, until a more experienced rider told me about matching RPM. To most riders, this is nothing new, but to some, it's a grain of knowledge to be stored and used. When I adjusted my technique, missed shifts went away, (except when I'm lazy) and finding neutral became easy. Got to get your right wrist, your left hand, and your left foot to work together to shift smoothly.
Apologies for trying to resurrect a dead post lol. Mine says 5th anytime I'm in a gear, but still shows blank for neutral, any ideas?
gswanson, OEM gear selector or aftermarket?
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,507 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 655 04-18-2024, 03:01 AM
  Power source for oil indicator led norton1974_imp 1 267 12-31-2022, 10:07 AM
  Service indicator - unleashed j3gq_imp 6 602 07-27-2021, 03:12 AM
  Rear indicator design problem Mixagon_imp 5 497 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
  Turn Indicator Switch question Scotty_imp 6 477 09-22-2020, 11:58 AM
  Gear shift indicator stuck on 4 bflint 39 2,534 03-11-2020, 02:46 AM
  Changing indicator lamps max 1 201 12-02-2018, 07:47 AM
  Sometimes Ending Up Between Gears With Gear Indicator Line Blinking 2017CB1100EX-STL_imp 27 1,950 08-03-2018, 12:35 AM
Last Post: apex1_imp
  Motorcycle doesn't start, high oil temperature indicator comes on Saarang_imp 17 1,164 07-20-2018, 07:14 AM
Last Post: SportsterDoc
