No spark, no start engine. Help me ;/
I have a problem with starting my Honda CB1100 (2013) motorcycle.
I had a small accident (slide).
I do not have a spark on the motorcycle, the motorcycle does not start.
After turning the key, the HISS lamp goes out and the fuel pump is working.
By pressing the start button, the motorcycle does not start, no spark.
All fuses without damage. I am looking for nothing, nothing results. Sad
Sorry to hear of your fall and hope you are well.
Perhaps a kill switch was damaged in the fall? Check the kickstand switch since that might have been damaged in the slide.
Good luck!
It seems to me, but I could be wrong, that you have to turn the kill switch to off and then back to on after a drop.
Couple questions.. You know for sure that there is no spark, or it just won't start? Iin other words you are saying it turns over but doesn't start, right?
Do you have it upright, in neutral, with the side stand up? (or on centerstand, in neutral with the side stand up). Have you recycled (turn off and on) the ignition switch? Have you checked and recycled (put sidestand down and back up) the side stand switch ? Have you checked and recycled (turned it off and back on both directions) the emergency kill switch?
Which side of the bike hit the pavement?
Is the engine turning over? If so, try holding the throttle wide open while starting. If you have not tried already, remove one spark plug, connect it's plug wire, hold the base of the plug against the cylinder head and turn the engine over to see if there is a spark across the plug gap.
Good questions, thus far:
1. Does the starter motor operate ("crank")?
2. How do you know there is no spark? Was it tested as suggested?
In gear the clutch needs to be pulled (or clutch switch jumpered) AND side stand up (switch closed), with stop/run in run position for starter to operate. All are in series.
In neutral, the clutch switch closed and side stand switch closed does not matter, as that circuit is parallel to the neutral circuit. Do you have neutral indication?
Since you can hear the fuel pump, the fuel pump relay should not be an issue.
Other than a wire broken/disconnected, likely issues are:
A. Engine stop relay
B. BAS failed to reset (cycle stop/run switch)
The stop/run switch is powered by the fused white/black wire and the black wire feeds the engine stop relay coil.
The engine stop relay coil circuit is completed via the red/orange wire to the BAS. The BAS, energized by the a white/black wire from same fuse, closes the red/orange wire to the green wire for ground. Jumpering the BAS connector, red/orange to green, should bypass it.
When the engine stop relay coil is energized, it closes contacts from white/black (switched power) to the red/white wire to the starter relay switch. Jumpering these two positions should bypass the engine stop relay.
Ignition coils are energized by white/black wires (switched power) and the secondary circuits completed by the ECM, positions A12 and A3
(03-19-2018, 12:42 AM)EmptySea_imp Wrote: It seems to me, but I could be wrong, that you have to turn the kill switch to off and then back to on after a drop.
Yes, I understand that a tilt interrupts switched power (white/black) in the BAS, which interrupts red/orange to green.
BAS is the Bank Angle Sensor for those not knowing.
So yes:
The starter spins, the fuel pump is working properly.
The presser foot sensor works properly.
The neutral position sensor also works correctly.
Does the tilt sensor need a restart? Could it be damaged?
I made a jumper, no positives.
According to the diagram, if the fuel pump is running at all, the BAS is not the problem.
Since the pump runs (we have to take your word for it), the BAS, Engine Stop relay and Fuel Cut-Off relay and stop switch (kill switch) are working properly. Also, the 20A and 10A and 30A main fuse in the circuit have to be good. And they appear to be or the circuit would not work.
The problem is somewhere else. Also keep in mind that we do not have the HISS in the US and it is not in our manual. Max may be able to speak to that.
Again, how do you KNOW you don’t have spark? And what side of the bike hit the ground?
Is the check engine light on?
For good help, you have to be very specific in your answers.
I second Redbird's suggestion. Hold the throttle wide open while starting. That worked for me with similar symptoms after changing battery. It apparently resets the TPS.
  NGK spark plug options Jonnyteabag_imp 6 603 08-05-2026, 11:35 PM
Last Post: JRD
  spark plugs after 70.000 Km DAC 16 1,466 12-23-2025, 10:15 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,469 10-23-2024, 02:50 PM
Last Post: rtmoto1
  High engine revs on start up CBX1000_imp 21 1,757 06-06-2024, 02:40 AM
  Spark plug socket. Jgarciajr40_imp 5 551 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 326 06-27-2023, 01:19 PM
  CEL after Jump Start rage91_imp 23 1,529 04-14-2023, 01:25 AM
  spark plug caps alexzanutto_imp 3 388 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 771 10-08-2022, 12:22 PM
  Won't start RLS_imp 5 445 05-12-2022, 05:58 AM
Last Post: RLS_imp
