Dimensioned Parts specs resource?
Forgive me if this is the wrong place to ask this, but i figured if anybody knows....
Would you kindly direct to a dimensioned OEM parts spec resource? specifically, I'm looking for the exact dimensions and specifications of the OEM gas tank on the '14 model. I need to pass it off to somebody who's making a doodad for me and can't get to my bike in person to measure.
I didn't know there was such a thing
I’ve never seen anything like that and its not in the service manual. Would be nice to have some engineering drawings, but I haven't seen any.
Here is a sketch: http://www.2wheelpros.com/oem-parts/2014...-MGC-N40ZC
With a ruler and caliper, you can add critical dimensions.
thanks for the input folks. i was seeking this out because there's a guy making some custom leather bags for me in another country, and i figured it'd be safer to send him some sort of official dimensioned diagram of the tank. Looks like it's gonna come down to me and my lucky tape measure.
Sorry to not be of more help. Typically, Honda provides no data, not even thread size/pitch for fasteners.
As an example of how little info is available from Honda, when researching price and availability for a stock Honda 15410-MFJ-D01 oil filter, I have not found any specifications/dimensions.
Whereas after market oil filters, such as the K&N 204*, have abundant info:
Anti Drain Back Valve Yes
Bypass Valve Yes
Filter Material High Flow Premium Media
Gasket Material Nitrile Rubber
Height 2.813 in (71 mm)
Outside Diameter 2.594 in (66 mm)
PSI Relief Valve Yes
Thread Specification M20 x 1.5
Product Style Oil Filters
Weight 0.5 lb (0.2 kg)
Removal Nut Size 17 mm
*Not recommended, due to recent nut spot weld issues.
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 652 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Spoked wheel run out specs Jfro5687_imp 3 318 04-19-2020, 06:35 AM
Last Post: Jfro5687_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 910 04-13-2020, 05:47 AM
  Torque specs for handle bar clamp to triple clamp itstuantran_imp 8 668 07-11-2019, 10:16 PM
Last Post: itstuantran_imp
  torque specs? Flynbulldog_imp 30 2,137 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,236 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque Specs for fuel pump Mscb1100_imp 5 540 03-13-2018, 03:38 AM
Last Post: Flytech99_imp
  SW Motech engine guard torque specs greekcb_imp 2 304 10-05-2017, 09:57 AM
Last Post: greekcb_imp
  Exhaust header torque specs run-tmc_imp 2 268 04-09-2017, 03:20 AM
Last Post: run-tmc_imp
  Torque Specs for Handle Bars ? Chapomis_imp 3 288 05-20-2016, 08:31 PM
Last Post: Chapomis_imp
