cb1100 fault codes reading and erasing
The following video shows where to find the service connector, how to access it and read stored fault codes.
it also shows a way to erase these codes with the help of a small wire jumper once the fault has been repaired or connectors have been replaced during service.
https://youtu.be/iwSllBQNsWc
this video is only intended for suitably competent riders with some knowledge of repairs to assist with their work.
max.
(05-04-2018, 12:04 PM)max_imp Wrote: The following video shows where to find the service connector, how to access it and read stored fault codes.
max.
Well done, Max!
FSM 5-!4 does not reveal the resistance (<1500 ohm) of the "special tool". Kudos for supplying that info.
Meanwhile, I'll work on qualifying to be competent. Might need some help counting, without getting distracted!
*LIKE*
  Check engine light/codes Carguy1959_imp 17 1,173 08-24-2018, 03:00 PM
Last Post: itstuantran_imp
  Diagnostic Trouble Codes & Sensor testing SportsterDoc 29 2,371 02-20-2018, 11:08 AM
  How to read fault code Jeya_imp 4 405 11-01-2017, 05:09 AM
