Check engine light/codes
Does anybody know how to read/find codes for reading the check engine light. My bike has been starting hard lately and this morning it bucked and the check engine light came on and stayed on all the way to work. I have replaced the spark plugs, battery, checked/cleaned the air filter, oil is fine. Bike has 6300 miles . Rode daily. Mostly highway. No mods to drive train. I did open up the stock muffler. I had also bought a next to new muffler and put it on 6 mo's ago. My 09 Harley FXDL did the same thing and it was the crank position sensor.
Any clues?
Carguy, as in so many matters technical, popgun may well be your man. I'm sure he owns a cable and bit of software he got from Healtech that allows him to interrogate the ECU. It plugs into a red plug under the left side cover. I'll see if I can find the thread.
Edit: Here you go. It's probably only a little bit of help, but there is a link to the Healtech site, http://cb1100forum.com/forum/showthread.php?tid=8666
By the way, Carguy, the user manual warns against riding the bike when the PGM-FI light is on other than at start up. It says, "reduce speed and take the motorcycle to your Honda dealer as soon as possible."
On page 5-10 of the '13 service manual there is a method for determining the main Diagnostic Trouble Code (DTC) by observing the Malfunction Indicator Light (MIL) blinking pattern. This will only give you the main DTC code, not the subcode. On page 5-12 of the '13 service manual there is a table of DTC codes and equivalent MIL blinking number.
If there is a DTC stored in the ECM, there should be a MIL blinking pattern that will allow you to determine the main DTC code.
With the side stand down, turn on the ignition and see if the MIL starts blinking. You can also have the engine idling but the side stand must be down. If the engine RPM is over 1700, then the MIL stays on and does not blink. If there is no MIL blink pattern then there is no DTC error code stored in the ECM.
short blinks last 0.5 seconds and long blinks last 1.3 seconds. One long blink is equivalent to 10 short blinks.
One short blink is equivalent to DTC main code 1.1
9 short blinks is quivalent to DTC main code 9.1
One long blink and 2 short blinks is DTC main code 12.1 (one long blink = 10 short blinks so 10+2 short blinks = 12)
I can post a picture of the DTC index on page 5-12 of the '13 service manual if the moderators say it is ok.
(04-26-2017, 01:49 PM)Carguy1959_imp Wrote: Does anybody know how to read/find codes for reading the check engine light. My bike has been starting hard lately and this morning it bucked and the check engine light came on and stayed on all the way to work. I have replaced the spark plugs, battery, checked/cleaned the air filter, oil is fine. Bike has 6300 miles . Rode daily. Mostly highway. No mods to drive train. I did open up the stock muffler. I had also bought a next to new muffler and put it on 6 mo's ago. My 09 Harley FXDL did the same thing and it was the crank position sensor.
Any clues?
Well that stinks.....best of luck and let us know what you find out, please. 2013 or 2014 bike?
I'm out of town right now, but brought the '13/14 manual for just these occasions Wink
What Curly typed is the same for the '14's
You may have multiple codes stored too. If you post your code or codes, Curly or I can tell you what it is.
(04-26-2017, 07:57 PM)curlyjoe_imp Wrote: On page 5-10 of the '13 service manual there is a method for determining the main Diagnostic Trouble Code (DTC) by observing the Malfunction Indicator Light (MIL) blinking pattern. This will only give you the main DTC code, not the subcode. On page 5-12 of the '13 service manual there is a table of DTC codes and equivalent MIL blinking number.
Apologies, but please don't.
If you need them Carguy, PM me your phone # and I'll take a pic and text it to you.
Thanks for the info. I have a 13-14 manual. My manual has the directions on 5-12 and 5-13. I will check them tomorrow.
Be interested to hear what it is, Carguy.
So, I did what it said, short the green and brown wires in the red 4 wire harness. Turn on fuel, turn on key, the light comes on .3 seconds and then blinks 8 slow blinks and 5 fast blinks. There doesn't seem to be a code in my book for 8-5. I checked the blinks about 20 times, justsayin.
Photo First Check Engine Light Ever on a Bike doug1976 2 229 01-14-2026, 06:47 PM
  engine light tpo12001_imp 16 1,441 01-14-2026, 05:26 PM
  Check your clips! Gone in 60 3 624 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,409 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 679 08-22-2024, 09:39 AM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,266 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Oil light turn on/off with hot engine Alessandro78Rome_imp 3 432 07-03-2023, 10:18 PM
  Sound check what wrong tory_imp 3 425 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,946 01-13-2021, 12:36 PM
  Oil level difference between check zirconxi_imp 29 1,868 06-27-2020, 09:11 AM
Last Post: redbirds_imp
