K&N Filter Recall
Not sure if this is relevant, but it seems so...
From the Iron Butt Assn. newsletter:
“As many in the long-distance community have heard, some K&N oil filters have been have been leaking oil and recently, some race tracks have issued notices that riders would be responsible for any track damage caused by running a K&N oil filter (effectively banning them as no one could afford those costs).
K&N has finally issued a SAFETY RECALL and identified which filters are subject to the defect. Here are clips from the recall letter sent to dealers:
K&N has discovered that certain KN-204/204C oil filters manufactured between March 1 and September 30, 2016, can leak oil at the area where a nut (intended for use to remove the oil filter during routine oil changes) is welded to the end of the filter. If there is such a leak, oil could come into contact with the rear tire or rear brake of the motorcycle on which the filter is installed. If this were to occur, it could lead to a loss of control or a crash. Therefore, K&N is conducting a recall under which it is offering to replace the covered oil filters at no charge, including the cost of return shipping.
A copy of the letter sent out to dealers with many more details and how to identify a recall filter is located at:
http://www.ironbutt.org/KandN/RCMN-17E044-1798.pdf
if you use K&N filters you should invest the time to make sure you are not using one of this filters or have one in your personal stock to use.
Mike”
(06-19-2018, 10:20 PM)EmptySea_imp Wrote: Not sure if this is relevant, but it seems so...
Mike”
Definitely relevant for CB1100 owners...
Thumbs Up
Yep. My date is good on mine
Previously posted:
K&N, more expensive than Honda, (~$17 vs ~$13) had a batch with spot weld control issues on the 17 mm welded on "nut", resulting in oil leaks.
https://www.knfilters.com/mobile/recallkn204
I continue to use Honda oil filters.
  Oil Filter dave 12 550 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,482 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,510 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,892 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,553 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,472 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 909 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,205 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,921 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,383 09-07-2021, 07:44 AM
