Batterie check
For years I have used a Tecmate tester called TestMate mini.
Connect it to your batterie using a SAE connector and you can check the batterie voltage, cranking voltage and charging voltage.
They are cheap and well made by the Tecmate company , they also have many great chargers and make the Honda ones as well.
Some years ago I met the gentleman from South Africa at the AIMEXPO whom started the company and at that time still owned it.
Quality products they have: check their website.
The website is under Optimate name.
i use the optimate5 charger....
It ALWAYS good to hear about proven quality product.
Thanks Houtman
I use similar model as above.
Photo First Check Engine Light Ever on a Bike doug1976 2 223 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 607 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,363 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 665 08-22-2024, 09:39 AM
  Sound check what wrong tory_imp 3 416 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,853 01-13-2021, 12:36 PM
  CEL on after installing new batterie on 2017 Houtman_imp 8 564 12-06-2020, 02:07 PM
  Dead batterie on my 2017 Houtman_imp 6 557 12-04-2020, 10:04 AM
Last Post: LongRanger_imp
  Oil level difference between check zirconxi_imp 29 1,803 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  cam chain check max 0 183 04-22-2020, 08:26 AM
Last Post: max
