CEL on after installing new batterie on 2017
This morning I installed a new OEM Yuasa batterie on my 2017 and when I took it for a ride this afternoon (50 miles) the CEL stayed on from when I started the bike . The bike runs perfect , 14 volt charging from bike and instant starting. The bike might have been without a batterie for 15 at the most. Does a code have to be reset on the 2017 , the CEL did not come on when I put a new batterie on my 2013 and 2014.
Can I reset it myself or does it need a dealer reset ? Dealer is close by for about $20 they did reset it a few years ago after an aborted O2 eliminator on my 2017.
Email sent.
2013-14 shop manual, page 5-13/14, or different page for 2017 in this chapter: fuel system (PGM-FI)
Here is little bit more:
http://cb1100forum.com/forum/showthread.php?tid=14655
http://cb1100forum.com/forum/showthread.php?tid=14997
http://cb1100forum.com/forum/showthread.php?tid=10612
https://www.amazon.ca/Honda-070PZ-ZY3010...TQDNU...or a simple jumper wire
Thanks Peter ; I just went out to the garage and put on the ignition , after the fuel pump stopped I slowly opened the throttle , started the bike and the MIL/ CEL did not come on ! That is now but hopefully stays that way , will take out again this week.
All this was done after I had a nice White Labs beer called Better Haze Ahead !
This is a local Asheville Yeast Lab making there own beer and selling yeast nation wide.
My motto is : no problem big enough in life a few beers can not take care of . JOKE
John, beer alone may not help...you also need some beautiful servants...Tongue
Glad you fixed it!!
Beer
John just adding to the information;
The cel was likely set when you started the bike with the old battery and a no-start.
This happened to me on the cb1000r, it had a "hiccup moment " when i started the bike, i red the code ( with the dlc connector procedure ) and from memory it was 67 or something like that.
Could not find the explanation for this code and reset it by the same method, no adverse effects were ever present so i assume it was a low battery code.
glad to know it has cleared and as far as i understand; blinking cel is current event, solid cel is a historic event.
Thanks Peter and Max , it is so great to have smart AND helpful members on this Forum.
Houtman is right , a lot of great folks on here with lots of great information that’s very helpful. I sold my 2013 cb1100 now with much regret. I replaced it with a 2020 Triumph Speedmaster. I have had some issues with it since new. Now at only with a 1000 miles on it , I wish I had a forum to lean on like what is here. I still check in regularly for some needed sanity.Again thanks to all the great folks here.
Sorry to read about the Triumph issues obleo. I am coming across quite a few disgruntled recent owners of Triumphs. It is a bit of a surprise.
  Installing RLETs on a CB1100 (All Models) rdprdp01 15 1,346 09-16-2024, 12:12 AM
Last Post: Race_ca1
  Dead batterie on my 2017 Houtman_imp 6 549 12-04-2020, 10:04 AM
Last Post: LongRanger_imp
  Batterie check Houtman_imp 2 274 07-16-2018, 08:22 AM
  K&N Filters: use grease when installing Ulvetanna_imp 4 465 06-26-2016, 01:48 PM
Last Post: Ulvetanna_imp
  Help installing chic rear fender MikeOxbig_imp 4 367 09-28-2015, 05:27 AM
Last Post: Motogeezer1949_imp
  Problem installing aftermarket exhaust MrTim_imp 12 735 09-08-2014, 08:38 PM
