OEM Fuel Tank Replacement Questions
Yesterday, I ordered a replacement fuel tank (2014 CB1100 Standard, black) on Partzilla:
https://www.partzilla.com/catalog/honda/...-fuel-pump
On the illustration, it is item "4": 17520-MGC-N40ZC TANK, FUEL (TYPE3)
I looks like it comes with the Honda wing tank badge, tape, etc.
But my Question is:
Does the tank already have the red stripe decal on it, or is that a separate item I should have ordered?
It appears on my existing fuel tank, that decal strip has clear coat covering it. The decal stripe I am talking about:
https://www.partzilla.com/catalog/honda/...00-ac/mark
or https://www.partzilla.com/catalog/honda/...-ac/mark-1
I also ordered the:
Item 7: 17574-MFA-D00 GASKET, BASE
Item 11: 17711-S0X-931 RETAINER
What happened? Two very embarrassing drops:
The evening before my Berea Rally trip, I was in a hurry to load and strap down my CB on a typical Home Depot utility trailer...(by myself with little motorcycle trailering experience). I has the right side strapped and was tightening the left front ratchet. While tightening, the strap got bound-up. While unbinding the strap, it let loose and the right strap pulled the Cb over, landing onto the trailer side rail. The side rail put a crease dent along the lower side of the tank and dented the muffler can (OEM replacement also ordered). The second drop was when I was parking the CB in Berea which resulted in a torn RLET (already replaced) and a scratch in the muffler can.
Suhawk
It will come with the stripes, but without the badges. You should be able to get some 2 sided tape from a local body shop and transfers wing badges from your original tank
The original pump gasket and blue green fuel pump clip should transfer ok it you want to try.
I ve swapped tanks and pumps several times with no gasket or fuel clip leak.
When I ordered mine , OEM Japan/Takashi, came with stripes, badges, completely painted...I only had to transfer : gas cap & f/pump ass-y....1/2 hr job depending how much gas is left in your present tank.
Hope this helps.
pb
Thanks guys. I check with Mr. T first. His prices were pretty good, but I save over $100 USD with Partzilla (no shipping charge).
Mscb, Maybe we should get together and I will video you breaking a time record of swapping tanks, even faster you did in Berea! Lol. Seriously, your description of the fuel line disconnect will help me, when that time comes. I seen various posts on this forum on that subject.
[Image: 5f9bcaeb27f9b3b4543f78f4de01abc1.jpg]
Well my new fuel tank, with the wing badges and red trim stripes, was delivered today. Unfortunately, Partzilla pack all the parts in one box, which included the muffler. The tank has two nasty dents, probably due to the muffler’s mounting bracket finding its way through the packing material to the tank side. The muffler gasket was squished. Unbelievable! The box revealed some some rough handling by UPS. I am working with Partzilla to get replacement parts. Meanwhile, I will ride with my original tank, which is not that bad.
In case anyone is wondering, the fuel tank did not come with the warning labels! You have add the labels to your order. ROFL
Ouch!
Dumba.....
That is their own fault for being so stupid as to put anything in the box other than the tank.
I really hope they don't try to push that liability & replacement cost off onto the shipper.
(07-05-2018, 08:32 AM)PowerDubs_imp Wrote: Dumba.....
You are right on both points Josh. I told the Partzilla service rep that the tank should of been in a separate box, but they still wanted pictures of everything including the box so they may make a claim again UPS.
I just got my return shipping label. Let them sort it out.
Still not a ringing endorsement for them. Companies can have great sales people and great prices and be killed by the people in their shipping department. Every bit as critical as all the rest but so many neglect it.
Too bad, suhawk. Pretty sloppy work by Partzilla, though.
  CB1300 headlight bucket replacement spechg 5 381 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 991 01-19-2026, 05:09 AM
  CB1100RS fuel tank rust Narciso 12 1,357 09-27-2025, 02:06 PM
Last Post: tdbru
  Rear brake pad replacement LongRanger_imp 39 3,607 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 523 02-13-2025, 06:25 AM
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 908 12-29-2024, 03:22 AM
Last Post: Karidis
  CB1100 fuel tank upgrade johnnyH_imp 3 445 03-13-2024, 01:31 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 499 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  More oil questions Maturecheese_imp 10 784 06-27-2023, 03:53 AM
  Fuel filter replacement Mafd2_imp 36 2,891 02-11-2023, 01:54 AM
