More oil questions
I'm thinking of using Motul 10w30 JASO MA2 in my Honda CB1100RS (as it's not flaming £50) but the recommended oil is JASO MA The extra 'grab' on the clutch isn't a problem but here's a question from someone that knows nothing about oil does that extra 'friction' result in faster wear?
MA2 should be fully backward compatible with MA.
The Motul 10w30 will work fine.
Ps. Total oil quantity will be between 3.8 and 3.9 quarts. The manual incorrectly states 4.2 quarts. Put in 3.8 and follow the sight-glass for the last lil bit.
Yes, Motul 10W30 5100 (semi synthetic) and 7100 (full synthetic) are nice for a used CB1100 mill. 10W40 works well too.
Motul 5100 semi synthetic will be fine for your CB1100 Maturecheese. The bike runs well, clutch engages smoothly, and you can save some coin - especially when you find a sale.
I used 5100, until I discovered and switched to full synthetic JASO MA/MA2 diesel 5W40 oil (like Rotella T6).
And according to another member, the oil quantity is actually LESS than 3.8 quarts. Put in 3.5 and gradually adjust upwards from there.
I overfilled mine a couple times trying to follow the manual.
Thanks for the help all I will definitely use the motol 5100 and see how it goes.
(06-12-2023, 05:17 PM)Maturecheese_imp Wrote: Thanks for the help all I will definitely use the motol 5100 and see how it goes.
I use exactly that, not noticed anything untoward but then I didn't expect to. It is a slightly murky looking oil from new so just to bear that in mind when draining on the next oil change, it isn't as bad as it looks.
... and don't drink it. Motul 5100 tends to smell delicious, ... for engine oil. Confused
I'm glad i referred back here as for a moment i thought I had ordered the wrong oil. The Motul 5100 is semi synthetic and I thought I should have ordered 7100 fully synthetic. Incidentally does anyone know if the Honda 10w30 'synthetic technology' is semi or fully synthetic?
https://prohondaoils.com/products/#4-stroke
i run this myself with a member ship i got 4 quarts for 70 bucks shipped and then you get a discount on purchases if membership is added to cart
https://www.amsoil.com/p/10w-30-syntheti...e-oil-mct/
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 925 12-29-2024, 03:22 AM
Last Post: Karidis
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 706 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
  Chain & Sprocket Questions arse-onist_imp 12 944 08-14-2019, 09:39 PM
  OEM Fuel Tank Replacement Questions suhawk305 18 1,118 09-02-2018, 02:28 AM
Last Post: suhawk305
  Side engine cover questions. pedro_k_imp 10 615 08-22-2018, 11:57 PM
  Questions. In General MrJayGLA_imp 6 487 07-30-2018, 03:17 AM
Last Post: HansenCB_imp
  Questions For Moriwaki 4 Into 4 Owners 2017EX_imp 1 231 07-11-2018, 08:55 AM
  New CB1100 Owner - Few Mechanical Questions mike85_imp 11 915 06-09-2018, 07:54 PM
Last Post: HondaJon_imp
  Oil change questions... ride4now_imp 16 1,029 04-12-2018, 02:12 PM
  Brake pad questions INTP_imp 37 1,973 03-01-2018, 03:10 AM
Last Post: Nortoon_imp
