Chain Tensioner Adjustment - How To ??
My other bikes had a section in the under seat manual on how to do this, but the CB does not.
Only done a few hundred miles of the break in period so far but would be interested on how it's done.
Can anyone point me to a thread with pics or an extract from the full service manual.
I am a 2016 CB1100ex if that makes any difference - but I suspect this will be a common process for all models.
I can see the tensioner body and I am guessing you have to remove a cover to set where the crank is before releasing the plunger / removing the assembly.
Thanks for looking guys.
I would strongly advise to buy the shop manual for your model CB 1100.
(10-14-2018, 03:06 AM)markT_imp Wrote: My other bikes had a section in the under seat manual on how to do this, but the CB does not.
You can donwload the manual from Honda:
http://motos.honda.es/manuales/index.php?codigo=Street
That looks like the owner's manual, which will not cover the adjustment to which he is referring. He would need the factory service manual for that.
Somewhere on this forum is a tutorial — how ever I tried to look for it using the search feature no luck. Seems you could look under chain adjustment , don’t know why didn’t find it. Maybe one of our esteemed moderators could help .
Guess not - - 36 pages on cams though !
MarkT, try looking at the thread labeled Crankshaft Balancer Backlash Adjustment post #65.
Popgun may have what you are seeking. I need to learn how to post links.
Ben
BACKLASH ADJUSTMENT as per my 2013-14 CB1100 manual is covered on p. 11-37/38..and I assume that from 2014 and up models is the same ???
It does not say how often ??
Hope this helps.
Can send you PM/email only of service manual pics due to copyright law.
Smile
(10-15-2018, 01:12 AM)peterbaron_imp Wrote: BACKLASH ADJUSTMENT as per my 2013-14 CB1100 manual is covered on p. 11-37/38..and I assume that from 2014 and up models is the same ???
Hope this helps.
Smile
thanks guys I will try and look up the article Ben refers to.
what is the symptom (sound effect) of balancer back lash anyhow?
shop manual links
https://imgur.com/qe8g0Mc
https://imgur.com/H2ofXaF
  Valve Adjustment Shims dave 13 656 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 608 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 851 08-29-2025, 10:46 AM
  Cam Chain Tensioner/Lift ? bflint 6 844 07-18-2025, 10:56 AM
  Valve Adjustment Intervals CBRider_imp 32 2,784 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,103 04-04-2024, 08:18 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,475 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Front forks adjustment Olyrider 5 476 05-16-2022, 11:04 PM
Last Post: Sparky80_imp
  Mirror Adjustment Question deltamark 14 1,276 03-12-2022, 03:53 AM
  Does my 2013 CB100 REALLY have no clutch adjustment? Olyrider 13 1,091 09-23-2021, 02:41 AM
