PAIR valve hose connections
After valve inspection I think I reconnected the right side incorrectly, after stumbling upon a parts fiche..
There are two hoses, I reconnected the long hose going to the air box to the rear most of the two, noticed it was really loose, going back on. It should go in to the front I believe.
Am I correct?
thanks
Yep, just looked, the front goes to the airbox, rear one to the rh pair valve, they cross over each other.
Pair valve crosses on outside, airbox on the inside.
You are correct, they need to be swapped.
(12-17-2018, 05:50 AM)max_imp Wrote: Yep, just looked, the front goes to the airbox, rear one to the rh pair valve, they cross over each other.
Thanks for the time and confirmation.
  Valve Adjustment Shims dave 13 735 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 646 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 874 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 977 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,100 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,575 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,477 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,675 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,864 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 662 07-08-2022, 03:41 AM
Last Post: 1973cb750
