Engine break out tips and tricks
Lads I’ve got my bike brand new.Any tips and tricks will be more than welcome!How to break out my engine?
None. Just start and ride right away. Be smooth with it, specially when cold (but don't warm it up by iddling).
Avoid using maximum power before the first oil change.
After that, just be smooth when cold and you'll be fine
The quality CB engine design probably has lots of margin built-in. Commonsense as jtopiso suggests.
I brought my air-cooled baby home in temperature of -25C (+ windchill) . A 45 minute ride averaging maybe 80 km/h. It ran beautifully - no complaints, and none since then.
As long as you are not an abuser, just ride it as you normally would.
Two schools of thought on this subject. #1 ride it like you stole it ,and #2 easy on the rpms under 3000 until 600 miles no constant speed vary throttle . Change break in oil at 600 miles still go easy until second oil change ,no red lining the tach ,then ride it as you want .
Thx for ur help.Got another tip from my friend just open throttle gently and let engine rise rpms slowly up to 5k.Than close and do same thing again that make engine more open.
What do u think about semi sintetic oil for the 1 oil change as a final polish for the parts and than stick for a full sintetic?
And now its an oil thread Big Grin Cue up the popcorn eating smiley. Celebrate
Stick to the regular GN4 dino for the first couple of changes. ( ... more butter please ... )
Or not! Go right into Motul 5100. ( ... mmmm, thank you, thank you very mucsh ... , ... , oh gravy, ... yeah ... )
  What did I break? Cbcarolina_imp 4 393 12-03-2023, 10:44 PM
  New members tips max 54 4,157 10-29-2023, 12:11 AM
  Some valve adjustment tips and tricks. LakeWylieJoe_imp 58 5,317 01-18-2021, 02:06 AM
Last Post: bflint
  Location of Engine Number on Engine? cb1100_dude_imp 2 324 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  IACV Replacement Tips snackie_imp 22 1,340 11-29-2018, 11:16 PM
  Engine break in test - recommended vs aggressive chync_imp 7 638 11-23-2018, 06:21 AM
  RANGE and BREAK IN Streetshark07_imp 9 783 11-15-2018, 03:02 PM
Last Post: Streetshark07_imp
  tips for busting extremely tight frame bolts? misterprofessionality 54 3,638 10-04-2018, 01:59 PM
Last Post: SportsterDoc
  Break pads.....just in time....so eaaaaaasy!!!!!! jdvalero_imp 16 1,011 08-12-2018, 09:32 AM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 695 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
