Break pads.....just in time....so eaaaaaasy!!!!!!
I give it half a mustach on the 1-5 difficulty Beard scale.
You only need a 12mm and a 8mm socket or wrench.
Wow that's getting your moneys worth out of your old pads. How many miles?
(04-09-2018, 12:31 PM)The ferret_imp Wrote: Wow that's getting your moneys worth out of your old pads. How many miles?
7895 Mls
I guess I do a lot of rear braking.
Rotor is in perfect shape....very little wear.
Now I know my limits (or at least I have a reference) on how long my rear breaks will last.
Sintered metal pads will give the brakes a whole lot more 'bite' ... something to keep in mind when you're trail braking deep into corner on a wet day Wink
That's why I order a new set of Bridgestone Battlax BT-45's
Curious as to what others use!
7895 Mls
7895 Mls
My reference is 35.000km for the rear pads. I mainly use the rear brake, the front brake pads are still original at 45.000km. Different geographics and riders...
Wisedrum
7895 Mls
7895 Mls
Wisedrum
Riding style makes all the difference. I usually let the engine slow me down whenever possible. I'm still on the original pads at 24K miles and they have a long way to go.
My CB750 went 39K miles before the front pads were worn. My old Nissan truck went 98K before I had to replace the front pads. It's just the way I drive.
I just cannot fathom that many miles on a single set of rear pads....The fronts have about 3/4 left from new. Hels bells what did I do wrong?
did the pads drag ? or do you use the rear more than you have to ?
I use the front brakes a lot more than the rear , rear most for stabilizing the bike and in town.
jdvalero, not to sound condescending or anything like that, but could it be your foot is resting on the brake pedal causing your rear brake to wear out substantially sooner than what others experience? I ask because several members have commented on the tight spacing down there and the way the foot peg is set, it's easy for the left edge of the front of the boot to depress the pedal without the rider realizing it. When I first got my CB, I had just read of that on the forums here and more than once when I looked down I noticed that my boot was indeed half on the brake pedal and I didn't even know it.
  Brake Pads... Simplified Yata-Garasu_imp 20 1,767 03-02-2025, 08:28 PM
  What did I break? Cbcarolina_imp 4 394 12-03-2023, 10:44 PM
  Any one use Ceramic Brake pads? mvk24_imp 6 642 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  brake pads which is best? modmaster_imp 32 2,242 08-27-2021, 10:21 AM
Last Post: jimgl3_imp
  Suggested brake pads? mvk24_imp 12 975 03-21-2021, 04:05 AM
  Rear brake rotor and new pads Sandhog_imp 13 925 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Correct part number for front brake pads Frulk_imp 7 595 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 987 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,176 02-04-2019, 01:47 PM
  Engine break out tips and tricks ACE_IRA_imp 7 496 01-29-2019, 12:30 PM
