Ticking noise
I have a ticking noise, when you roll on the throttle in any gear at 1500 rmp to 2500, you can hear a ticking noise. I suspect the valves needs adjusted. Bike only have 1200 miles on it.
Am I correct in thinking the valves need adjusted?
Greg, valves don't call for inspection until the 8,000 mile check. Swing by your dealer and have them take a listen it. Probably nothing, but thats why you have a warranty and they have a service dept...to set your mind at ease.
It should not be the valves unless they were not set right at factory. Could be related to the noise on this thread.
http://cb1100forum.com/forum/showthread.php?tid=2479
That linked thread is my thread i started. The noise in the first video sounded normal to me. Granted it was parked for the winter but the warm up sounds normal. Now that bottom end noise in the second video, that is another story.
Sent from my XT1055 using Tapatalk
look back on threads, the ticking noise has been worried about since the beginning, not sure it turned out to eb anything for most people. Dbuster has more than a ticking noise
Hard to tell without a recording of the noise. You can hear the fuel injectors ticking when applying throttle.
Oh yea, your right Guth. Gosh the memory sucks sometimes. Everyone though they were having pre detonation ( pinging under load) from low grade fuel or something, turned out it was fuel injectors ticking.
Good memory, thanks for the reminder. Thumbs Up
I have not heard any ticking noises from my bike , the one blessing when your hearing is going !
This thread was from April last year, right after we all started getting our bikes
http://cb1100forum.com/forum/showthread....+injectors
Good read..source for ticking noise revealed in post 15
Air cooled bikes make more noises in general and yeah the super quiet exhaust doesn't help to hide that. Mine does it low down in the rpms too.
  Front wheel bearing noise? MagnaRider 20 1,625 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,031 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 912 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 439 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 904 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 563 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 637 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,415 03-18-2021, 01:22 AM
   Ticking / clicking sound after oil change simplest2remember_imp 12 833 02-03-2021, 01:32 AM
  Strange wizzing noise LoyalKhan664_imp 28 1,875 10-02-2020, 05:58 AM
