K&N Filters: use grease when installing
I pulled out my K&N air filter today as I noticed oil leaking from the clear drain line from the airbox. No oil in the airbox but a very fine layer of dust. Realized I had not used the installation grease. Had a tube from years ago, greased it up real well and reinstalled.
I'm going to check again in a couple of thousand miles and if there is any sign of dust, going back to OEM air filter.
I have never been a fan of oiled filters. actual filter performance is sub-par compared to the OEM paper filters. They are great for race cars that get rebuilt often, not so great for something used on the street for commuting.
Yup. Lots of cars (but not our CBs) run into problems with the oil contaminating the MAF too. I've never really felt them worth it for a vehicle that sees lots of miles.
(06-26-2016, 04:27 AM)Ulvetanna_imp Wrote: I pulled out my K&N air filter today as I noticed oil leaking from the clear drain line from the airbox. No oil in the airbox but a very fine layer of dust. Realized I had not used the installation grease. Had a tube from years ago, greased it up real well and reinstalled.
What "grease" are you talking about?
What "grease" are you talking about? K&N makes a special grease that is intended for coating the mating surfaces where the filter seals against the airbox. The issue is with the design of the filter, it does not fit the same way as OEM so a grease is applied to give a good seal. It's pretty thick.
(06-26-2016, 10:28 AM)kennyw_imp Wrote: I have never been a fan of oiled filters. actual filter performance is sub-par compared to the OEM paper filters. They are great for race cars that get rebuilt often, not so great for something used on the street for commuting.
Yep, I think I'll toss it at the next service and go back to OEM. PITA to clean and re-oil, too.
May change my mind and keep it if the inside of the airbox is pristine at the next checkup though.
I am also noticing the Mobil 1 full synthetic oil finds its way out of the engine quite well. And the bike seems to be consuming it as compared with the semi-synthetic Honda oil I was using, 10W40 grade.
  Installing RLETs on a CB1100 (All Models) rdprdp01 15 1,357 09-16-2024, 12:12 AM
Last Post: Race_ca1
  Counterfeit Oil Filters 2017EX_imp 111 8,796 03-24-2023, 01:31 PM
Last Post: 808_rider_imp
  CEL on after installing new batterie on 2017 Houtman_imp 8 584 12-06-2020, 02:07 PM
  K&N Oil Filters BEWARE!!! davidsargee_imp 150 10,062 01-27-2020, 10:46 AM
  Air Filters BIGGREEK_imp 20 1,395 02-18-2018, 10:50 PM
Last Post: jimgl3_imp
  K&N oil filters .. known issue..FYI the Ferret 13 831 11-24-2017, 01:32 AM
  Grease Ninja - chain lube applicator Huladog_imp 14 1,000 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  Help installing chic rear fender MikeOxbig_imp 4 381 09-28-2015, 05:27 AM
  Problem installing aftermarket exhaust MrTim_imp 12 748 09-08-2014, 08:38 PM
