Help Needed with My DLX
I am changing the thread about getting a DLX, to HELP needed. I am still working on it, hitting the harder stuff to do. When I hit a bump, I will respond with my latest dilemma. Right now I have asked for help on the other post on how to remove the left side cover, and the smaller one on the right side; and have gotten some help from our ever so helpful Forum members. I will take any advice whatsoever because I am attempting task I have never done before.
Thanks in advance !!!!!
Michael, do you have Honda Service Manual?
(06-14-2021, 11:00 AM)peterbaron_imp Wrote: Michael, do you have Honda Service Manual?
yes
Went back and looked into my service manual, the thick one for all years, and it says nothing about how to separate the parts, just warns of the magnetic field holding them together. I actually have most of the pages dogeared for all the work I have to do. Did it back when I got the bike. Most sections do give tips & procedures, but not this part.
Use a small plastic tool to get it loose, once it’s free you should be able to overcome the magnetic force. Not too hard. I have changed mine twice , don’t ask me how I know. Oh well two stupid drops.
Obleo is correct.
A few of plastic wedges are very essential and place'em not far away from the dowels.
Also, in your case, as the bike was sitting outside for years, there might be some corrosion between corresponding parts that works as glue and making separation more difficult.
Patience will prevail.
As to the Honda shop manual, I thought you didn't have it...of course, not everything is detailed.
(06-14-2021, 11:23 PM)obleo_imp Wrote: Use a small plastic tool to get it loose, once it’s free you should be able to overcome the magnetic force. Not too hard. I have changed mine twice , don’t ask me how I know. Oh well two stupid drops.
Small plastic wedges like those used to help level freshly laid down floor tiles?
You could also try a hairdryer on maximum heat, or a heatshrink/paintstripper gun if you are careful, to the casing to bring it through several heat cycles. The effect of it slightly expanding and contracting may loosen surfaces and joints.
Thanks, I will try this.
(06-15-2021, 01:53 AM)Tev62_imp Wrote: You could also try a hairdryer on maximum heat, or a heatshrink/paintstripper gun if you are careful, to the casing to bring it through several heat cycles. The effect of it slightly expanding and contracting may loosen surfaces and joints.
Thanks for the tip . I went to a different part of the bike to work on. I sprayed some stuff that is supposed to break thru corrosion, so I will work on other stuff as it does its work.
You can also use the cheap type putty knives that are made of plastic. You can also buy small plastic wedges used to level up toilet bases.
  Parts needed Midwestbiker_imp 2 319 02-26-2024, 10:34 PM
Last Post: 1973cb750
  ABS - help needed The Gecko_imp 19 1,378 11-03-2022, 03:12 AM
Last Post: max
  brake maintenance advice needed misterprofessionality 5 448 12-08-2021, 06:57 AM
  under the hood pictures needed j3gq_imp 6 554 10-29-2020, 08:39 AM
Last Post: LakeWylieJoe_imp
  Hi I'm new here. Help needed please web81e_imp 6 458 01-06-2019, 10:09 AM
Last Post: iamheero_imp
  Rear Brake Help Needed White Dog_imp 21 1,592 10-01-2018, 07:10 AM
Last Post: Jim21680_imp
  Advice needed Spiderwatts_imp 6 1,081 10-21-2017, 11:42 AM
Last Post: Spiderwatts_imp
  removing rear wheel on CB1100NA (RS) Care needed Macduff_imp 1 244 07-28-2017, 11:54 PM
  Gasket needed or not? INTP_imp 5 468 11-18-2014, 01:20 PM
Last Post: Kai Ju_imp
  cbr 929 rear end conversion help needed! hahadumball_imp 4 395 07-28-2013, 03:24 AM
Last Post: thumper_imp
