Gasket needed or not?
Hello,
I will be replacing the cover on the left side of the crank case. I do not see any gasket shown in any parts sites. Is a gasket needed, or do I just use Yamabond?
(08-11-2014, 07:43 AM)INTP_imp Wrote: Hello,
no gasket , hondabond #4 or yamabond
I am in same situation as Kevin. So Hondabond can be used as a
substitute for gasket? I tried to remove the original
Crank case but it seems well bonded to the
Engine case despite removing the bolts. Do
I knock it off by gently tapping it with a
Hammer? What is the best way to take the
Original crank case off when replacing it
With silver polished one I bought from
Samurider. Please let me know. Thanks
Naveed
Sydney Australia
You can not use Yamaha bond on a Honda Motor cycle !
Naveed.... Rubber or wooden mallet only..no metal hammer.
Be aware that the ACG exerts quite a bit of pull so that may contribute to the problem of getting cover off. Not to mention the locating dowels that ensure that moving parts don't touch stationary parts.
As far as sealing the cover goes, Honda has been using Hondabond on certain covers for quite some time now.
Make sure you get all the old stuff off and apply the new stuff very sparingly. Less is more. You just want an even, paper thin film. Any excess will be sqeezed out and can end up inside the engine. I've seen engines ruined due to excess sealant blocking vital oil passages.
Also, when you put the cover back on the magnets will try to yank the cover out of your hands. If your finger tips are wrapped around the edge it will hurt, I guarantee it. I think there is even a warning in the service manual to that effect.
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,598 11-16-2025, 12:01 PM
Last Post: TheLegend
  Left Side Crankcase Gasket Part number. jbird06_imp 1 320 03-26-2024, 08:56 AM
  Parts needed Midwestbiker_imp 2 311 02-26-2024, 10:34 PM
Last Post: 1973cb750
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 466 02-21-2023, 07:51 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 386 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  ABS - help needed The Gecko_imp 19 1,353 11-03-2022, 03:12 AM
Last Post: max
  Gasket maker peterbaron 16 1,145 05-21-2022, 10:17 AM
  brake maintenance advice needed misterprofessionality 5 440 12-08-2021, 06:57 AM
  Gasket Pushing out? rdeleon975_imp 13 913 10-22-2021, 02:07 AM
  Help Needed with My DLX michael1954 9 760 06-15-2021, 11:59 PM
Last Post: Obleo
