Advice needed
I love this bike. It is beautiful in black and the overall quality of fit and finish on this bike is stunning.
I have a Yoshimura slip on for a little extra sound. And thanks to this forum a K&H high seat coming from Japan in next few weeks.
The seat to peg distance is ok but my long legs need more distance.
Hopefully the taller/firmer seat will help.
Tonight I removed the rubber covers on the rider footpegs. It will give me about 1/2 inch more room and will help my ankle angle with the rear brake pedal. Multiple ankle injuries make bending my ankle challenging.
I thought about getting an extra set of extra passenger pegs and using them to replace the standard rider pegs. The knurled surface on them looks good and overall the passenger pegs are very high quality.
Any recommendations or advice is welcome. Thanks.
I have put the Vario foot pegs from Germany on my CB 1100's
They are 360 degree adjustable , very well made but not the cheapest.
+1 on the adjustable pegs. I use them.
There is a cheap set for sale on the Forum , buy them quickly !
Spiderwatts, I'm near 6'4" and feel a little bunched up with stock seat. But I dislike spending $$$ on a new seat when it's not the seat that's the problem, it's the height...as in mine. I have a kneeling pad--fairly firm foam--that's about 2" thick and I set that on my seat, then bought a $20 mc seat pad that has straps that go under the seat and gives another 3/4 inch of thickness. When the seat straps are tightened down (they go under the seat) it holds the kneeling pad in place. Overall, it gives me about 2.5" higher ride, and makes long distances do-able--I rode OR-to midwest and back and the increased leg room saved my hips and knees. The only drawback was that it pushed my legs out a little wider than normal, but once I got used to that, no problem. Ok, visually, it's not perfect, but if people are looking that close while I'm riding...then they've got other issues.
Found a photo
The K and H seat will make a big difference.
I did see this in the FOR SALE section (Lower Pegs)
http://cb1100forum.com/forum/showthread.php?tid=11647
Thanks for info!
(10-21-2017, 03:31 AM)pdedse_imp Wrote: Spiderwatts, I'm near 6'4" and feel a little bunched up with stock seat. But I dislike spending $$$ on a new seat when it's not the seat that's the problem, it's the height...as in mine. I have a kneeling pad--fairly firm foam--that's about 2" thick and I set that on my seat, then bought a $20 mc seat pad that has straps that go under the seat and gives another 3/4 inch of thickness. When the seat straps are tightened down (they go under the seat) it holds the kneeling pad in place. Overall, it gives me about 2.5" higher ride, and makes long distances do-able--I rode OR-to midwest and back and the increased leg room saved my hips and knees. The only drawback was that it pushed my legs out a little wider than normal, but once I got used to that, no problem. Ok, visually, it's not perfect, but if people are looking that close while I'm riding...then they've got other issues.
Found a photo
Looks pretty good. Great idea.
  Advice please--maintenance on new to me CB LucienLeFranc 11 763 06-24-2026, 01:34 PM
  Parts needed Midwestbiker_imp 2 300 02-26-2024, 10:34 PM
Last Post: 1973cb750
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,182 04-23-2023, 01:35 AM
  ABS - help needed The Gecko_imp 19 1,331 11-03-2022, 03:12 AM
Last Post: max
  Clutch replacement advice misterprofessionality 31 2,395 06-11-2022, 05:51 PM
  brake maintenance advice needed misterprofessionality 5 438 12-08-2021, 06:57 AM
  Help Needed with My DLX michael1954 9 749 06-15-2021, 11:59 PM
Last Post: Obleo
  under the hood pictures needed j3gq_imp 6 507 10-29-2020, 08:39 AM
Last Post: LakeWylieJoe_imp
  Removing bar end mirrors - need advice Endeavour_imp 5 468 08-15-2020, 02:20 AM
  Fueling and Air overhaul imminent. looking for any advice misterprofessionality 111 7,851 05-08-2019, 12:14 PM
