First Tire swap
Hello people. I’m finally getting new tires for my 2014 cb1100. I don’t have the manual and my friend is helping me put on the new tires. Luckily he has a lot of experience and the necessary tools to do this.
We finally managed to get a pair of Z8’s.
Anything I need to keep an eye on?
Does anyone know the necessary torque values?
Thanks in advance.
My front Z8/110-80-18 is tar snake sensitive, especially new and after 3000 kms (presently)
Torque specs (ft-lbs):
* front axle bolt - 44
* front axle pinch bolt - 19
* rear axle nut ('13) - 83
* rear axle nut (after '13) - 69
Good luck
(08-12-2021, 01:25 AM)peterbaron_imp Wrote: My front Z8/110-80-18 is tar snake sensitive, especially new and after 3000 kms (presently)
Good luck
Thanks. From all the review I read the z8’s stood out most to me. Let’s see how they feel once swapped
Any chance anyone know the torque values for the front and rear brake calipers
Nope, Nobody knows Big Grin
OK, just happen to have the book out for another thread.
Front brake caliper mounting bolt (4) 23 Ft lbs ALOC bolt replace with new
Rear brake caliper pad pin: 13 ft lbs (10mm)
Rear brake caliper pin bolt: 20 ft lbs (12mm) ALOC bolt replace with new
Rear caliper bolt: 16 ft lbs
Most do not replace ALOC bolts but put a thread locker on there.
(08-15-2021, 02:27 AM)Lord Popgun_imp Wrote: Nope, Nobody knows Big Grin
Thanks
  2017 Tail light housing swap dogclerk_imp 0 205 07-05-2022, 12:31 AM
Last Post: dogclerk_imp
  tank swap j3gq_imp 0 184 01-03-2022, 10:43 PM
Last Post: j3gq_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 951 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Tank Swap rbike_imp 1 197 02-08-2016, 12:55 AM
  Camshaft Swap SimiPair_imp 25 1,473 01-03-2016, 09:29 AM
Last Post: Motogeezer1949_imp
  interesting info, possible parts swap thread. hondatillthedayidie_imp 14 907 05-04-2015, 03:19 AM
Last Post: kDiqq_imp
