interesting info, possible parts swap thread.
So i read this cool article last night from japan where a jounalist went and interviewed everyone on the design team for the cb1100 platform.
http://world.honda.com/CB1100/engineer-talk/episode1/
So as it turns out, the 1100 is based largely from the cb1300 super four platform.
The engines are very similar just one is air cooled.
Lots of good info in here. Maybe based on this we could start a parts swap thread?
All Hail Hirofumi Fukunaga ! Great article
[url=http://s1298.photobucket.com/user/aswreed/media/design%20team_zps0wd5exls.jpg.html][Image: 8b4c3bb8828726b8042d3b543b3b52a9.jpg]
I want a Silver CB
The CB1100 and CB1300 share valve springs, crankshafts, air filter element, cam chain tensioner assembly, entire clutch boss, basket, plates and everything is shared EXCEPT springs (CB1300 has stiffer springs), and water pump. The pistons (from what I can see) are a larger bore and dished differently for higher compression. Rods are probably a different length as well. I just gave a quick look and those are a few PNs I was able to match. Hopfully that can help start a parts swap list. Not that it does Americans any good as we didn't get the CB1300 Sad May open up some aftermarket options though!
The ebay in the u.k. has parts for the 1300 all over. Even entire engines for around 300 euros. Looks like the handlebar controls are the same and the outer engine covers. The article also states that the frames are similar. Id be pretty cool i think to do a franken-cb project with the whole 1300 engine. Pop in a radiator somewhere and plumbing for coolant. It looks as though the throttle body assembly is the same as well, of course it would require some tuning of the ecu.. It would be a pretty cool one-off though
The throttle bodies are fairly different. I can't tell you from parts diagrams, but the 1300 is missing a few pieces the 1100 has. Also injector size is different and the 1100 has more vacuum routing. Don't let me discourage you though! I'd be thrilled if you could manage to punch out the 1100 to a 1300 and run 1300 pistons and rods. We already know the crank is the same, so as long as you have an extra 200cc in the cylinder walls, it shouldn't be hard to do as long as the valve timing and angle doesn't cause PTV with the decreased combustion chamber size. Actually, the valve recesses in the 1300 pistons would be totally wrong. You'd have to use some kind of custom piston.
I would swap the whole engine, just for simplicity's sake. You could either put the 1100 throttle bodies on the 13 engine, or use the 13 throttle bodies and fab the ecu to compensate.. I dont think there is a head stay mount in there, so you may be able to swap the whole engine as a bolt on assembly, assuming there is enough room for the cylinder head under the tank.
Why would the valve recesses in the 1300 pistons be wrong?
Great article. I didn't realize all the challenges involved in creating a modern air-cooled inline 4 and found this statement interesting:
The materials we arrived at with the right heat- and friction-resistance characteristics are the finest materials used in any production bike.
I like the power of my CB 11 but I have never been one to turn down more POWA !
(05-01-2015, 02:03 AM)hondatillthedayidie_imp Wrote: I would swap the whole engine, just for simplicity's sake. You could either put the 1100 throttle bodies on the 13 engine, or use the 13 throttle bodies and fab the ecu to compensate.. I dont think there is a head stay mount in there, so you may be able to swap the whole engine as a bolt on assembly, assuming there is enough room for the cylinder head under the tank.
So the valve PN is different so the size is likely different. But the big thing is the angle between the intake and exhaust valve. It's widened on 1100 for vertical clearance and looks. The cam valley is much narrower on the 1300.
Ah yes, now i understand what you mean. I wonder if the liquid cooled engine assembly from the 1300 would clear under the fuel tank?
I know it would compromise the whole look of the bike, but the 1300 powerplant isnt necesarily 'ugly'...
  Another tire thread: Dunlop TT900GP misterprofessionality 1 370 10-08-2025, 11:57 AM
  Another shock thread, but SHOWA JLEECB 17 1,847 02-09-2025, 11:23 PM
  another idle thread Tom_imp 11 1,073 11-20-2023, 01:30 PM
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 14,054 12-27-2022, 08:35 AM
   Dutch's High idle thread DutchRutter 17 1,651 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another Oil Thread dave 11 1,012 09-15-2022, 09:13 AM
  Interesting Maintenance YouTube Channel tommymck 4 439 09-10-2022, 03:14 AM
Last Post: alprider
  2017 Tail light housing swap dogclerk_imp 0 211 07-05-2022, 12:31 AM
Last Post: dogclerk_imp
  new tyres' thread j3gq_imp 0 202 01-03-2022, 10:52 PM
Last Post: j3gq_imp
  tank swap j3gq_imp 0 196 01-03-2022, 10:43 PM
Last Post: j3gq_imp
