Honda OEM Top Case wrong OEM rack
Hi All,
I've been sitting on a Honda OEM Top Case from samurai rider because I bought the 13' not the 14' rear carrier. Has anyone installed this setup on the 13' carrier?
(07-28-2021, 10:48 AM)iamlegend21087_imp Wrote: Hi All,
What you can do is buy the OEM rear carrier for the CB1100. With that buy the support and OEM accessory box from a CTX1300. I'm 99.999% sure the candy red is the same used on the cb1100. Plus you can use the key system to fit your key.
Pull up the ctx1300 and cb1100ex and you'll see... You have a red bike, correct?
  Just in case anyone is interested in what the inside of our starter looks like… PowerDubs_imp 14 1,148 07-14-2024, 05:05 PM
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,221 11-17-2022, 02:57 AM
  Sound check what wrong tory_imp 3 423 03-30-2022, 12:33 AM
Last Post: 1973cb750
  INSTALLATION instructions - Honda luggage rack JustPassinThru_imp 12 883 12-28-2021, 10:45 AM
  Weak Crank Case Bolts? bertypower_imp 19 1,530 09-12-2020, 10:22 AM
Last Post: bertypower_imp
  Rear brakes... what I did wrong and where to go now? Inhouse Bob 32 2,298 07-11-2020, 01:37 AM
  Help, need assistance in assembling a key tumbler for a Top case 17-CB-002 6 472 07-11-2017, 01:16 PM
Last Post: 17-CB-002
  Removing the Honda Rear Rack postoak_imp 6 447 08-06-2016, 06:50 AM
  What's wrong with my front tire? ride4now_imp 19 1,238 05-01-2016, 07:51 AM
Last Post: ride4now_imp
  In case you're curious, exhaust material kDiqq_imp 12 738 10-31-2014, 09:39 AM
Last Post: Insolentsquid_imp
