New Purchase Questions
Greetings, I think I'm getting close to purchasing the 1100 from a dealer several hundred miles from home and have a couple questions.
1. I have read per Owners Manual break in is 300 miles, does it mention RPM limitation are just the usual stuff like no full throttle?
2. What must be removed to gain access to battery terminals?
3. I'm thinking of a 4x1 exhaust system like the K or Yoshimura, do they both keep center stand and easy access for maintenance........is there a good 4x1 chrome system out there?
Thanks and I apologize if these questions have been asked before.
600 miles.
There is a tray that has to come off. Two screws last I looked, and you have to raise the seat to gain access.
Some keep the center stand, some don't, webbike world on their site say in their descriptions. I read them but didn't commit to memory as I don't intend to replace my exhaust with an after market one. No help there! Smile
FWIW.. according to the owner's manual, break in is set at 300 miles. I think engine manufacturing has improved to the point that finer machining/finishing tolerances are possible than could be achieved in the past for a given cost (?).
My liquid cooled CBR250 also had a stated 300 mile break in period. That was a bit of a surprise to find out at the time...
I need to closer then. For some reason 600 miles was stuck in my head. Thanks for the correction. Worship
Just looked under the seat; it appears only one screw is used to hold down the battery cover/stash bin.
How does the manual define break in?
Has anyone mounted accessory outlet off the battery?
Page 10 of the owner manual it states for the first 300 miles don't be a wacko and ride conservatively. No relines, no hard braking; in other words take it easy. Don't stress the systems.
First service is at 600 miles which I had assumed was the first break in period. Oops!
Different systems will break in at different rates. Brakes for example will set in much faster than the motor. Once the motor is fully broke in your mileage should be max'd out (provided your riding style does not change your mileage will improve until the motor is fully broke in).
I'm a bit surprised I have not added an accessory outlet on this bike; typically it is one of the first mods I do. It will have to wait a wee bit longer.
Is the oil filter the same type/part number that fits Wing, ST, VTX? I have a bunch of those.
We need a shrug gremlin. Smile I have heard the filter fits a number of bikes. My other hondas take different filters so I really don't know.
Actually I forgot to mention NT700 and Valkyrie with the Wing, ST, VTX..............they all used same type except one was shorter and I think it was the NT700 that if you used the taller filter the center stand would hit it. I had all those bikes within a couple years of each other, I bought filters in the big pack.
There is one screw and one push pin holding in the tray. The push pin you just push the middle of the circle in and it pops loose, you can then pull it out. Push the middle back up to rest and then stick in hole and push middle down agin to lock. Screw is a phillips. I installed a battery tender pigtail on mine, which also can power my mini air compressor for flat repairs, or with n adapter power my gps that I never use.
The oil filter fits a lot of the Hondas and the part number is listed on the first page of the how to do your own 600 mie service thread.
As far as break in, vary the engine peed, take back roads home, don't drone for 100 on the freeway. You will be fine.
  CB1100 Questions from a potential new owner E11even_Hunnit 88 7,492 02-12-2026, 06:02 PM
Last Post: E11even_Hunnit
  Buying 2014 CB1100 and have questions MagnaRider 31 3,076 09-06-2024, 05:24 AM
  Recent purchase, whats next? Classico_imp 8 661 03-28-2022, 03:36 AM
Last Post: apex1_imp
  Questions... Bazbro_imp 15 1,210 10-07-2020, 12:28 AM
  Beginner questions ceeko_imp 5 477 06-18-2020, 06:54 PM
Last Post: zirconxi_imp
  Basic question, about to purchase 2013 CB1100 non-abs AsHperson_imp 16 1,546 05-29-2019, 04:37 PM
Last Post: AsHperson_imp
  Couple of questions about the spoked wheels on the EX VLJ_imp 14 1,029 04-02-2018, 05:44 AM
  Hi thinking about getting a cb 1100 have some questions calipo223_imp 54 3,703 03-11-2018, 10:55 PM
Last Post: CB750F_imp
  New owner with a lot of questions.... jdinaz_imp 7 638 10-25-2017, 02:15 PM
Last Post: jdinaz_imp
  '14 CB1100A first ride and some questions Banned_imp 14 920 05-25-2017, 05:22 AM
Last Post: Banned_imp
