Threads: 31
To the best of my recollection, I've never owned a bike with spoked wheels. I checked the owner's manual, and there isn't a single mention of the spokes. I asked the service department, and they had no idea. So...
1. Do these spokes require any sort of maintenance? I know that the spokes on motocrossers and trail bikes require periodic tightening, but what about these spokes? Being a streetbike, are the wheels constructed in such a way that it obviates the need for spoke maintenance?
2. What's the best stuff to to use to clean them? Following the ride home from the 600-mile service, suddenly the rear wheel is absolutely caked in gunk.
Likes Received: 652 in 289 posts
Likes Given: 805
All spoke wheels need watching. Spoke flex at different rates in certain sections of the wheel and each spoke is expected to carry the same weight and stress, so when some flex and get looser, they are not carrying their fair share of the weight or stress. The loose ones need to be tightened to keep the wheel true. Much smaller deal on a street bike than on a dirt bike due to the nature of the terrain they have to deal with. Most mechanics have no clue to art of checking spokes and truing a wheel, most never having dealt with it. You find the loose ones by sound, tapping each spoke ..tink, tink, thunk ( there's your loose one that needs tightening) and a tightening twist with a spoke wrench is required to tighten it back up until it tinks again. However on most street bikes, it's highly unlikely that any spokes will stretch or come loose in a number of years, unless you hit pot holes or run into curbs etc hard enough to flex the wheel.
Oh and I'm the wrong guy to ask about cleaning.
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
(02-02-2018, 11:38 AM)VLJ_imp Wrote: To the best of my recollection, I've never owned a bike with spoked wheels. I checked the owner's manual, and there isn't a single mention of the spokes. I asked the service department, and they had no idea. So...
1. Yes, check for tightness periodically. Some will loosen. I rode my CB750F over a curb to park it at my shop daily for years. It was not the best for the front wheel spokes. If over-tightened or miss-tightened, the rim will not run true...even oscillate at high speeds. It took a dial indicator to get it back to normal.
2. The first miles will throw grease from the o-ring chain...so messier than normal. A wheel brush (automotive alloy wheel type) in a Dawn or other degreaser solution will clean up well. Using Dupont Chain Saver, throw from the chain has become less and less and less.
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
I can't tell from pictures how your spokes attach to the hub but..... I've been reading a book full of old Moto Guzzi Eldorado and Sport magazine reviews. In one article on the 750 Sport the author said the spokes went straight into the hub, no elbo joint like you see on most bikes. He claims that this arrangement greatly reduces the maintenance on spokes - without the elbo forces go directly to the hub with no offset force vector to cause it to loosen up. He said that spoke maintenance was not even mentioned in the manual.
Never heard of that myself, but thought it was a very interesting point so I tucked that factoid away in the brain pan. Had no idea it would be pulled out so soon.
I have no experience to back up that theory. Just checked - my Griso rear spokes have about a 5 degree bend before going into the hub. Have not inspected them since new. 15K miles ago.
I remember that the most I would do would spin the tire when off the bike and let a screw driver hit each spoke like playing cards on bicycles. I would listen for the same note on all the spokes.
Threads: 7
(02-02-2018, 12:49 PM)Rboe_imp Wrote: I can't tell from pictures how your spokes attach to the hub but..... I've been reading a book full of old Moto Guzzi Eldorado and Sport magazine reviews. In one article on the 750 Sport the author said the spokes went straight into the hub, no elbo joint like you see on most bikes. He claims that this arrangement greatly reduces the maintenance on spokes - without the elbo forces go directly to the hub with no offset force vector to cause it to loosen up. He said that spoke maintenance was not even mentioned in the manual.
I remember that the most I would do would spin the tire when off the bike and let a screw driver hit each spoke like playing cards on bicycles. I would listen for the same note on all the spokes. ------------------------------------------------------------------------------
You are correct, that is the most one should expect to do for spoke maintenance.
You can screw a wheel up real quick by trying to true it without any experience. It's an art form.
Threads: 28
In the 60s we use rely on an elderly bicycle shop owner for spoke tightening or wheel truing.
If you are using chain lube, the rear rim and spokes will get dirty from lube fling and road grime. Clean the chain and change to [url=http://www.tiroxproducts.com/chain-wax.html]Tirox Synthetic Chain Wax. It is white when applied and dries clear. It does not fling, and attracts less road grime.
I use Motul Chain Cleaner to clean the chain. It also works well with oil spills on the garage floor. I use to clean the rims and spokes with it. But I found that Honda or Ipone Cleaner and Polish works well. Because it is a polish, the rims and spokes stay cleaner and are easier to clean. Something like the wax on the chain. The Ipone is also good for cleaning helmets and their visors.
If you bike gets really greasy, Gunk is a great degreaser. I have used it for decades. Washes off like soap with the hose. Has a smell that every vintage motorcyclist will recognize.
Threads: 125
(02-02-2018, 01:33 PM)3rdbike_imp Wrote: (02-02-2018, 12:49 PM)Rboe_imp Wrote: I can't tell from pictures how your spokes attach to the hub but..... I've been reading a book full of old Moto Guzzi Eldorado and Sport magazine reviews. In one article on the 750 Sport the author said the spokes went straight into the hub, no elbo joint like you see on most bikes. He claims that this arrangement greatly reduces the maintenance on spokes - without the elbo forces go directly to the hub with no offset force vector to cause it to loosen up. He said that spoke maintenance was not even mentioned in the manual.
Yep, definitely one of those tasks where "proceeding with caution" is encouraged. A little tightening can go a long way. Go to far trying to correct a wobble and the next thing you know the wheel is out of round. But I'm also guessing that a bicycle wheel is likely more sensitive to minor adjustments than a motorcycle or car wheel would be.
Threads: 42
If you have don't trust yourself to check you spokes when you have your tire changed have the tech check them. When we had a shop we never trued or fixed spokes but we know people who we could count on to do it. It is sort of a lost art.
Threads: 7
WD40 is also great for cleaning up chain lube throw on spokes and rims. I've had 3 bikes with spokes. Keeping them clean is a chore but the price one pays for retro authenticity, good looks and better rim compliance. (Though Comstar-esque alloys have their own look and heritage.)
Threads: 8
I worked in bicycle shops for almost a decade during my teens and early twenties. We'd occasionally help out a motorcyclist who couldn't find a shop that could effectively true their wheels. As mentioned, a little goes a long way. If you've never done it, do a bit of reading. It's actually not that hard if you start gradually and realize that for every twist in one place, there is an affect elsewhere. We'd learn by using only 1/8th turns on the nipples and going from there. The biggest mistake I'd see by DIYers was over turning. Usually thinking they could get away with a full half turn. Disaster would ensue.
