Recent purchase, whats next?
My “new” 15 CB 1100 EX has 44000 miles and comes with no documented maintenance although I’ve been told by the seller that it’s been maintained by an Honda dealer by its first owner up to 40k mikes.
The bike is in very good shape aesthecally and the engine purrs nicely.
What should I plan to do on my first service?
Are 44k mikes cause of concern?
NO, 44K miles is not a concern. Empty Sea has about 50K, I have 64K on mine, I think Cormanus has 75K on his, and I think 2 of the members have over 100K without issues.
I would change the oil and filter, examine the air cleaner, check the tire pressures and check chain tension and adjust if necessary. Other than that ...ride.
Since you don’t have the maintenance records, I’d also recommend replacing the brake and clutch fluid. Take a peek at the brake pads as well.
Is it possible to find out from the seller where it was serviced? Then you should be able to see the actual service done. I would be most concerned when the valves were last adjusted or inspected.
(03-21-2022, 01:04 AM)pekingduck_imp Wrote: Is it possible to find out from the seller where it was serviced? Then you should be able to see the actual service done. I would be most concerned when the valves were last adjusted or inspected.
PO is trying to gather that info, puzzles me that he havent done so during his 3 yrs ownership!
I understand that valves’ inspection take considerable time (and money!) Wonder if an expert mech could hear valvetrain and judge without taking cams et al out
Take note of all other recommendations too, thank you all, gentlemen
The cams do not have to come out to check clearance. They do have to come out to adjust.
Classico some members have collected their valve adjustment values and mileage over the years in this thread which can give you an idea about what to do about your valves;
http://cb1100forum.com/forum/showthread.php?tid=14124
we have no reports of any valve related incidents in the past and this engine is under stressed, so good thoughts on the adjustment but no reason to worry, if the service has been carried out by honda it would have been done by them, maybe have a very close look at the valve cover bolts and look for signs of spanner marks on the hex flats in the "undo direction", these bolts require very low torque values but still.....
Oh and be advised about NOT using oil filters with a hex nut spotwelded on the top, they have failed and spilled oil mid-stream on the road, good to know.
Thanks Lord Popgun and Max, very useful info!
If the valve adjustment has gotten too tight, there is nothing to hear. It is common for clearances to tighten up over time as the valves close millions of times against the valve seats. When a valve closes, it transfers heat to the cylinder head. If clearances are tight enough to prevent the valve from closing fully, damage to the valve is possible.
  Whats it worth Chris Goldson_imp 19 1,615 08-26-2020, 02:00 AM
  Basic question, about to purchase 2013 CB1100 non-abs AsHperson_imp 16 1,535 05-29-2019, 04:37 PM
Last Post: AsHperson_imp
  Potential CB1100 purchase questions cb4me?_imp 27 1,703 09-06-2016, 02:20 PM
  Whats old is new again. Hiram E. Varona_imp 22 1,518 04-02-2016, 12:11 PM
Last Post: gmike_imp
  purchase inspection... crutch_imp 18 1,118 04-01-2016, 06:06 PM
  Purchase complete... quietguy_imp 27 1,586 12-21-2015, 08:44 AM
Last Post: quietguy_imp
  Cross country purchase? CB360T_imp 36 2,427 10-16-2015, 08:10 PM
  Update on my recent purchase, and some ride pics! kvdv_imp 11 923 08-19-2015, 04:40 AM
Last Post: drodg33
  whats the diff between the cb1100 and the cb1100f nitro50@comcast.net_imp 26 2,045 06-03-2015, 04:49 AM
Last Post: SanPete_imp
  Purchase negotiations 2014 Deluxe Stichill 44 3,061 05-01-2015, 11:18 AM
Last Post: DJS_imp
