Threads: 15
I have an issue trying to get my size 12W shoe under the shift lever. The lever is short and angled downward somewhat. I typically perform upshifts with the side of my shoe pressed against the edge of the rubber boot on the lever. Is the shift lever adjustable? Is there a longer aftermarket lever available? Moving it up 1/2" would make a huge difference. Will be removing the lever soon anyway to be able to bleed clutch fluid.
Thanks.
Likes Received: 575 in 312 posts
Likes Given: 957
Snow boots can be troublesome.
I stopped that practice many years ago.
Likes Given: 136
It is adjustable for up or down. Not a super lot but some. I forget how much and would have to look in the service manual to see if the amount is listed. I did mine when I bought it in '13 and haven't messed with it since.
Threads: 0
(03-08-2023, 08:32 PM)Wagonpeddler_imp Wrote: I have an issue trying to get my size 12W shoe under the shift lever. The lever is short and angled downward somewhat. I typically perform upshifts with the side of my shoe pressed against the edge of the rubber boot on the lever. Is the shift lever adjustable? Is there a longer aftermarket lever available? Moving it up 1/2" would make a huge difference. Will be removing the lever soon anyway to be able to bleed clutch fluid.
Thanks.
I have size 14's and had that problem as well on my 2014 ,yes the shifter linkage is adjustable and makes a world of difference
(04-29-2023, 11:30 PM)340duster_imp Wrote: (03-08-2023, 08:32 PM)Wagonpeddler_imp Wrote: I have an issue trying to get my size 12W shoe under the shift lever. The lever is short and angled downward somewhat. I typically perform upshifts with the side of my shoe pressed against the edge of the rubber boot on the lever. Is the shift lever adjustable? Is there a longer aftermarket lever available? Moving it up 1/2" would make a huge difference. Will be removing the lever soon anyway to be able to bleed clutch fluid.
Thanks.
Yikes! - size 14.
A big welcome to the Forum 340duster!
Likes Given: 136
Welcome 340duster!!
Pics of big feet or it didn’t happen
Likes Given: 957
(04-30-2023, 10:00 AM)Lord Popgun_imp Wrote: Welcome 340duster!!
I second that
Threads: 85
Likes Received: 41 in 24 posts
Likes Given: 123
Threads: 13
Likes Received: 79 in 49 posts
Likes Given: 45
I were a 12 w and I have no issue but I don't wear boots just shoes
