2013 Clutch issue.
Had to make a run to the local dump to drop off two old fridges. Used the low boy Kendon trailer for that.
Came back home and sun is shining. Mid 60’s and a cloudless sky. Decided to take the 2013 Tim Duncan Tribute Edition (#0021) out for its first jaunt this year. Unplugged trickle charger, removed dust cover. Pushed the Road King out of the way and wheeled the CB out onto the driveway. Fired right up on 1st key turn and purred satisfyingly for a minute. Got on it, engaged clutch and popped it in gear and bike lurched forward. Luckily I had the front brake on or otherwise I would have gone straight into the King.
Tried it a couple more times after pumping clutch lever but same issue. Clutch lever feels mushy/spongy. Reservoir is full but noted one tiny air bubble in glass. Since I already had trailer hooked up I opted to push the bike on and trailered it to local Honda dealer where I bought the bike.
I’m guessing clutch needs to be bled and fluid replaced. Checked all fittings. Nothing loose or seeping. No fluid on garage floor.
Only the second unscheduled routine maintenance trip to the dealer. The other being need to replace fork seals.
Not bad for a 12 year old bike.
A similar thing happened to my clutch after I'd changed the fluids and cleaned it all up. One of the rubber seals in the master cylinder was less than perfect. I rebuilt it and all was well.
I had this exact sort of issue not too long ago and thoroughly bled all the fluid out of the clutch lines until I couldn't see any more bubbles coming out and voila, clutch all fine again. In my case it happened because the fluid got too low and some air got sucked into the line.
(04-09-2025, 06:47 AM)misterprofessionality_imp Wrote: I had this exact sort of issue not too long ago and thoroughly bled all the fluid out of the clutch lines until I couldn't see any more bubbles coming out and voila, clutch all fine again. In my case it happened because the fluid got too low and some air got sucked into the line.
How did it happen, was there any leak??
Picked up CB1100 at dealer after they bled clutch lines and changed fluid. $116 with a 22 hour turn around. The 2013 TDTE CB1100 is back home.
So this is the second time the clutch and brakes have been bled in 12 years?
if $116 included clutch and brake fluid I'd say you got a deal.
No. Last time clutch and brake fluid was replaced was 2021. Bike doesn’t really get rode much. Have 4 bikes in rotation.
They changed clutch fluid only for $116
I’m in the mists of doing a major garage/shed clean out. Will be done this weekend making runs to the dump.
Once that’s done I’m doing machine maintenance. Trailering Guzzi to nearest dealer 220 miles away. Road King going to local shop for all fluids refreshed and new tires. Doing XR1200 oil change and brake bleed myself. Changing oil and plugs in an ATV and then hauling boat to dealership for some routine stuff. After all that doing brake fluid refresh in Honda CB1100 myself.
Might have to eat Ramen for a few weeks.
(04-11-2025, 08:40 AM)Frulk_imp Wrote: No. Last time clutch and brake fluid was replaced was 2021. Bike doesn’t really get rode much. Have 4 bikes in rotation.
Feel free to swing by with some Honda DOT4 anytime if you want to save a couple hundred and I will bleed them for you for half of what the dealer charges. Smile
  cycletrader security issue - selling your bike safely 562loosenoodle_imp 15 1,632 01-11-2022, 10:59 AM
   Gear Selector Issue aibrookes_imp 26 2,243 05-20-2021, 06:10 AM
Last Post: cj599_imp
  Arthritis and Clutch Lever jodytek_imp 37 3,277 04-18-2021, 03:48 AM
Last Post: michael1954
  Craftsman jack issue pdedse 3 370 04-27-2019, 08:44 AM
  2013 Honda CB 2013 CB1100AD K10 Whitehouse Rasher_of_bacon_imp 10 809 08-06-2018, 11:37 AM
Last Post: '64
  Dropped Bike / mirror issue tommymck 30 1,782 05-11-2018, 10:09 PM
Last Post: Bheezy27403_imp
  DCT w/Clutch. Have you cake and eat it too. activedirt_imp 18 1,304 04-24-2018, 01:10 PM
Last Post: Marc_imp
  Petty issue ..... but ,,,,,, ohiorider_imp 12 1,238 08-29-2017, 12:39 PM
  Battery issue paulw_imp 12 685 08-02-2017, 03:06 AM
  Clutch and Brake Lever Adjustment retroman_imp 6 552 06-18-2017, 12:53 PM
Last Post: NightRider_imp
