Dropped Bike / mirror issue
I know....they say that there are those that have, and those that will. Having said that, I haven't dropped a bike since my YZ80 as a teenager in the late '70s. I'm a pilot too, and they say that there are those who have landed gear up, and those that will, but I've always rejected that line of thinking.
Well, today, with my brand spanking new CB1100EX, I dropped it. I have my "excuses". I was riding to work and the right side mirror was flopping lose in the breeze. Pulled over into a parking lot to sort it out and my normal procedure failed me. Unless I'm parking on a grade, I shift to neutral, put the kickstand down and wait to turn the bike off until I get off if it. For whatever reason (maybe because I was thinking too much about the mirror) I put the bike in neutral, got off, but didn't put the kick stand down. Sinking feeling.
Here's the good news though. It fell towards the left (port) side and landed on the oil cap. Not a scratch on the tail pipe, not a scratch on the tank, not a scratch on the bars. Notta. Just a very minor scratch on the oil cap. What a perfect excuse to get the vintage cap that's been advertised here on the forum. And in any case, 15 minutes of buffing would render it good-as-new. Really, I'm shocked at the fact that I dropped the bike and essentially no damage was done. Yeah, I was very stupid to do this. But what a great design that you can drop the thing and not sustain any real damage.
Couple of lessons for me. First, no matter how long I've been riding, a new bike throws me off of my normal routine. Gotta make sure I develop fail-safe procedures. For whatever reason, my BMW procedure fails me. Second is that when things go awry, that's the time to pay particular attention.
Now, on to the mirror. So, this was a bit of a mystery. When I took delivery of the bike, the mirror seemed fine. I rode it a couple of days and I didn't notice anything. But (and this was the right / starboard mirror), this morning it was completely lose, which I only noticed when on the road (it was flopping in the breeze). The mirror stalk counter-rotates to screw in as it turns out. After I dropped the bike, and after I figured out that it tightens with counter rotation, when I tightened it up, it was 180 degrees out of what it needed to be. The mating "nut" can be adjusted also, but it was loose for any configuration that had the stalk snugly mated. When I go to the office, I found a couple of washers that made the whole thing work out, but "stock", I don't see how you could ever adjust things to work out. Wondering if anybody else has had this problem.
At the end of the day, my bike still looks spiffy showroom new with just the most minor scratch to the oil cap. Gives me even more confidence in the bike....
My 2014 mirrors became lose a couple of times....I even carry the correct size wrench in my bags in case it ever happens again.
Yeah...that's the thing.... There wasn't a combination of wrenches that would have made it work out for me. There is a nut with an internal thread that mounts to the bar on the 2017. The mirror stalk threads into the internal nut thread (counter-rotating). But if you tighten the nut to the bar, and tighten the stalk into the nut, when all is done, the stalk snugs up in the wrong spot. The mirror is in the wrong position (towards the interior of the bike.) The only way for me to make it work our was to add a spacer between the stalk and the mating nut. Works fine that way, and there is a cover that cleans the look up... but the thread length / design seem wrong.
Thanks for sharing what is a painful scenario for many of us. Glad it turned out alright and the bonus is that you have learned something. For this reason, I always put my bike in first before turning the ignition to off and kick the stand. Yes it may seem easier to use the kill switch or let the kickstand cut the engine but I have then forgotten that the ignition is still in the on position.
Amazed that the only damage done was to the oil cap...that’s great news. Sorry to hear of your mishap. A while back I did the same thing as you, forgot to put the kickstand down, while parking the bike in my garage. However, the bike fell on me as I was taking off my helmet. No damage done other than to my pride, and a sore back.
(05-07-2018, 01:38 PM)tommymck_imp Wrote: Yeah...that's the thing.... There wasn't a combination of wrenches that would have made it work out for me. There is a nut with an internal thread that mounts to the bar on the 2017. The mirror stalk threads into the internal nut thread (counter-rotating). But if you tighten the nut to the bar, and tighten the stalk into the nut, when all is done, the stalk snugs up in the wrong spot. The mirror is in the wrong position (towards the interior of the bike.) The only way for me to make it work our was to add a spacer between the stalk and the mating nut. Works fine that way, and there is a cover that cleans the look up... but the thread length / design seem wrong.
I think that you might do it wrong , get the stalk into the right position and than tighten the lock nut. After this you can adjust the mirror part a little but hold the stalk , some times walking into the mirror in the garage can loosen it.
I’m confused. It fell to the left? The oil cap is on the right. How did it get damaged?
Thank you, popgun. That’s exactly the question I was going to ask. Unless somehow the post is written from the point of view of standing in front of the bike looking aft.
Oh, and how could the oil cap get damaged anyway? It’s way too out of the way.
are these different than the 2014s? I just took my mirrors off the other day to remove my handguards. All I used was one 14 mm wrench to remove and tighten. Back off the top lock (jam) nut, unscrew the mirror, screw the mirror back down to near bottom and rotate it to where you want it, then tighten the locknut (jam) down, You could use another 14mm to really jam the two nuts together, but I didn't have to. Final adjustment is tilting the mirror itself.
(05-07-2018, 11:25 PM)The ferret_imp Wrote: are these different than the 2014s? I just took my mirrors off the other day to remove my handguards. All I used was one 14 mm wrench to remove and tighten. Back off the top lock (jam) nut, unscrew the mirror, screw the mirror back down to near bottom and rotate it to where you want it, then tighten the locknut (jam) down, You could use another 14mm to really jam the two nuts together, but I didn't have to. Final adjustment is tilting the mirror itself.
That's the way mine work and how I do it.
  2013 Clutch issue. Frulk_imp 7 867 04-17-2025, 10:46 AM
Last Post: Whoops
  Mirror, Mirror on the right... pdedse 11 876 12-11-2023, 03:47 AM
  Whoa- this CB1100 dropped a valve seat- PowerDubs_imp 13 1,291 10-23-2023, 11:43 AM
Last Post: 1973cb750
  Dropped CB1100 CB1100DLX_imp 48 3,445 06-24-2023, 04:39 PM
Last Post: FLYTYM_imp
  cycletrader security issue - selling your bike safely 562loosenoodle_imp 15 1,632 01-11-2022, 10:59 AM
   Gear Selector Issue aibrookes_imp 26 2,243 05-20-2021, 06:10 AM
Last Post: cj599_imp
  Craftsman jack issue pdedse 3 370 04-27-2019, 08:44 AM
  Well... I dropped her today... redReno_imp 54 3,208 04-23-2019, 09:42 PM
Last Post: jitaylor_imp
  Why is it so difficult to find a darn mirror? FLYTYM_imp 14 1,271 03-14-2019, 03:11 AM
  Dropped the bike today. crutch_imp 10 783 10-24-2017, 02:30 AM
Last Post: Nortoon_imp
