Has anyone installed a louder horn?
Doug Shepard_imp Offline
Threads: 22
I have almost been ran off the road a few times in the last 2 weeks. I would like to get a louder horn to get the attention! Not sure the DB on the factory one? Found these Hella Super Horns for 118 DB and look fairly decent as well. Interested if anyone has down this already?
Thanks!
11-03-2018, 11:01 AM
dsan1964_imp Offline
Threads: 18
(11-03-2018, 11:01 AM)Doug Shepard_imp Wrote: I have almost been ran off the road a few times in the last 2 weeks. I would like to get a louder horn to get the attention! Not sure the DB on the factory one? Found these Hella Super Horns for 118 DB and look fairly decent as well. Interested if anyone has down this already?
Thanks!
I have often thought about installing a different horn. In fact I was thinking of one I saw on a heavy duty all terrain forklift. It’s the same size that’s only a single not like our doubles same voltage I still might install one,
11-04-2018, 10:53 AM
Tezza_imp Offline
Threads: 20
RE: Has anyone installed a louder horn?
Stebel snail type horns are the way to go. i have a similar pair on my Honda and they fit in place of the original ones.
11-04-2018, 01:35 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
(11-04-2018, 01:35 PM)Tezza_imp Wrote: Stebel snail type horns are the way to go. i have a similar pair on my Honda and they fit in place of the original ones.
Tezza, I have a couple questions. Do you point them forward or to the sides? Do you run a relay?
11-04-2018, 03:31 PM
Tezza_imp Offline
Threads: 20
Tezza, I have a couple questions. Do you point them forward or to the sides? Do you run a relay? I have mine pointed forward with the outlet at the bottom in case they get water in them. No relay but considering the thin stock wiring
it's probably not a bad idea to fit a relay.
11-04-2018, 06:33 PM
Threads: 22
Thanks!
Interesting forklift horn are they loud?
That's an air horn right I was looking at one of those too but not sure about the hook up if easy
11-05-2018, 12:30 PM
Tezza_imp Offline
Threads: 20
They do make air horns. One of our club members has one of those on his CB125 and it sounds like a mack truck. I was talking about the snail type diaphram type.https://www.ebay.com/itm/High-Power-Stebel-Magnum-Twin-Electric-12-volt-136dB-Car-or-Bike-Horn-Kit-Loud/121599084940?hash=item1c4fdec98c:g:-ugAAOSwDaBb2p5N:sc:AU_StandardDelivery!4070!AU!-1:rk:3:Pf:0
11-05-2018, 06:49 PM
WhatYes_imp Offline
Threads: 6
I realize this thread is 5 years old now and I might not get any views/replies, but am looking at these for my 2013:
https://wolo-mfg.com/horns/motorcycle-ho...hrome.html
I like the ease of installation and the looks. Db rating is ALWAYS optimistic, but was wondering if anyone has any experience with these or other recommendations.
I've put PIAA aftermarket horns on other bikes and am considering those, too, but - again - I like the way these look.
05-02-2023, 01:40 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
(05-02-2023, 01:40 AM)WhatYes_imp Wrote: I realize this thread is 5 years old now and I might not get any views/replies, but am looking at these for my 2013:
Louder horns are always a wise investment. Snail horns like the Wolo are just like the flat disc horns you have, but with a false top cover and the scroll that directs the sound better and gives a bit of amplification.
But the instructions do not mention using a horn relay, which is highly recommended. A relay allows near-full battery voltage to go from the battery, through a fuse, and directly to the horn, rather than through the harness and flimsy switch contacts. Remember also to hook a nice ground from the chassis (or ideally, the battery) to the mounting plates.
Be sure to use the mounting plates provided because they allow the horn to oscillate. Solidly mounted horns are not nearly as loud. And using 2 horns of the same frequency will be louder, but not as penetrating and noticeable as 2 different frequencies.
05-02-2023, 02:15 PM
Tev62 Offline
Threads: 33
Likes Given: 95
I find the horns on my 2017MY EX the loudest on any bike I have ever owned. Were they poorer prior to that?
05-02-2023, 10:02 PM
   Horn Upgrade. Really LOUD air horn. OMG !!! Havasu Secret_imp 14 1,359 09-27-2023, 08:38 AM
Last Post: Havasu Secret_imp
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 396 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  2017 EX Horn on a 2014 Std CaptainChris_imp 27 2,049 10-20-2021, 04:48 PM
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 356 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 4,087 12-12-2020, 11:51 PM
  Anyone installed a radiator cover? bioman_imp 35 3,813 05-18-2020, 12:00 PM
Last Post: TXBikerGuy
  Givi Sport Bag installed on 2017 RS OEM Rack Mitch_imp 17 1,258 07-31-2019, 02:39 AM
  Road Comet installed ! greekcb_imp 10 904 06-03-2019, 06:14 AM
Last Post: glennrcompton_imp
  Horn/Flash Button Reverse Idea 2017EX_imp 16 1,499 10-10-2018, 08:50 AM
Last Post: redbirds_imp
  Horn Upgrades pekingduck 0 240 10-08-2018, 09:18 AM
