Chain guard extension
Delphisa Offline
Near by Grenoble, France
Threads: 28
Likes Received: 48 in 7 posts
Having found sometimes a few grease particules onto the rear carrier (where my wife holds her hands...) I tried the following bricolage to reduce grease projections over rear of the bike :
To make this, I used some rubbish I found in my garage : a thin piece of black PVC (0.6 mm), and an aluminum plate, 2 mm thick:
Once assembled with a bolt and nylstop nut, it looks like this: (I also put a double-sided adhesive layer between the aluminum and PVC tab)
Not sure it will be really efficient, but it should capture a part of the flying grease - I hope so ! Wink
Jean-Pierre
06-11-2014, 03:48 AM
Website Find Reply
shdwghst457_imp Offline
Threads: 22
RE: Chain guard extension
Clever!
06-11-2014, 03:53 AM
Papa Weeley_imp Offline
Threads: 44
Very nice! Thanks for the share!
06-11-2014, 04:06 AM
wayne van horn_imp Offline
Threads: 0
I have the same problem, I guess honda saved $1 dollar in plactices to make the chain guard 6 more inches longer!
06-11-2014, 04:29 AM
Ridem32_imp Offline
Threads: 51
Nice looks like it should work fine. I would try it out on a few rides and see the results. Then I would replace the bolt with a black rivet Smile
06-11-2014, 04:47 AM
Greg_imp Offline
Threads: 8
My solution is to not use grease, but that looks okay!
06-11-2014, 04:50 AM
AzBob_imp Offline
Threads: 6
This thread was worth it just to see "bricolage" used in a sentence.
What chain lubricant do you normally use? I use the Pro Honda Chain Lube with Moly stuff and I don't think I've ever had any fling anywhere. At least not up high enough to hit the rear carrier where it would be noticed.
06-11-2014, 07:46 AM
Houtman_imp Offline
Threads: 115
I use the Honda one and no flying off any where.
Over the years I have found that the Honda products for cleaning and lubricating are very good.
06-11-2014, 07:59 AM
Ridem32_imp Offline
Threads: 51
AzBob: I saw the word bricolage but thought it was something Delphisa just made up. I did not want to say nuttin to hurt his feeling lol
06-11-2014, 08:11 AM
Threads: 44
Whatever lube the factory/dealer used on my chain is making a mess. I've got a thick, tacky, Vaseline-like covering all over my rear wheel.
06-11-2014, 08:31 AM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 2 476 04-14-2025, 05:16 PM
Last Post: deuce17EX
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 11 974 04-11-2025, 02:41 PM
Last Post: rdprdp01
   Tank Guard Options Yata-Garasu_imp 11 737 05-18-2022, 08:11 AM
  Front Fender Splash Guard Wagonpeddler_imp 26 1,663 03-03-2022, 05:45 PM
Last Post: jtopiso_imp
  2014 Shift Lever Extension Modification, Replacement? HeavyMetalMech_imp 12 1,066 08-02-2021, 10:29 AM
Last Post: HeavyMetalMech_imp
  Brake lever guard for track days mrded_imp 17 1,269 05-26-2021, 07:50 PM
Last Post: mrded_imp
  PLOT Chain Guard KiowaEagle_imp 14 1,139 09-30-2020, 12:31 PM
Last Post: tod.branko_imp
  we know this engine guard ? alprider 1 317 06-27-2020, 07:32 AM
  Shield Extension Crazyirv_imp 3 338 05-28-2020, 11:22 AM
Last Post: Crazyirv_imp
  Oil Cooler Guard Chris Goldson_imp 10 937 11-09-2017, 11:41 AM
Last Post: Dvassino_imp
