PLOT Chain Guard
KiowaEagle_imp Offline
Threads: 36
PLOT Chain Guard
The other night I was riding home and heard some metal tapping going on. It wasn’t a long ride and as soon as I got off I found it immediately, my PLOT chrome chain guard had broken just above the rear screw. I remember thinking when I installed it that the metal seemed thin and that part of it seemed a little flimsy but I figured plenty of people had them and I never heard of anything breaking so it must be alright.
I don’t have anyone riding with me on the CB and I don’t recall anything hitting it so I can only surmise it’s a stress fracture, maybe the metal was bad there. In looking at the break the metal seems brittle to my untrained eye.
So anyway I contacted Takashi and no, there is no warranty on an almost two year old chain guard. I didn’t expect it but it doesn’t hurt to ask. So now I’m thinking about trying to repair it. Mainly because I’m not about to spend that kind of money on another new one. Especially if the lifetime is only two years. But I’m unsure what the best way to repair it would be. So I’m asking you metallurgists out there....what are your thoughts?
[Image: 6c7b5db46d868348fbc798d45079d079.jpg]
[Image: beaa3e3de3aa9c5443334f71e8bd73ea.jpg]
09-28-2020, 10:52 PM
Houtman_imp Offline
Threads: 115
RE: PLOT Chain Guard
I have the Plot chrome chain guards on my 2013 and 2014 from the very beginning and I just checked them and they are still very solid . Did yours "vibrate " a little over time and got metal fatigue ?
09-28-2020, 11:20 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
This happened to one other member too. I hope mine holds up.
I can't remember what he did to fix his. Maybe I'll search some and see if I can find it.
OK, here is the guy-- http://cb1100forum.com/forum/showthread....#pid198300
Threads: 36
(09-28-2020, 11:20 PM)Houtman_imp Wrote: I have the Plot chrome chain guards on my 2013 and 2014 from the very beginning and I just checked them and they are still very solid . Did yours "vibrate " a little over time and got metal fatigue ?
That's the only explanation I can come up with but both screws were tight so it shouldn't have been vibrating. At least not excessively.
(09-28-2020, 11:20 PM)Lord Popgun_imp Wrote: This happened to one other member too. I hope mine holds up.
Thanks Popgun, I don't think a washer alone is going to do the trick though. I'm thinking of reinforcing it in some manner from behind but I don't think a piece could be welded there without discoloring the chrome. Maybe using an adhesive.
09-28-2020, 11:40 PM
peterbaron Offline
Likes Given: 996
This probably broke due to vibration and skinny end design, which cannot absorb vibration and weight of the chain guard.
I would not fix it .
I would chrome plated existing plastic chain guard and reinstall it back.
This may not meet your expectation but this is what I would do.
On the other hand, to accommodate vibration, you may prefabricate canvas reinforced rubber strap, shape it to the guard's end then gently rivet it (tubular or semi-tubular type) to the inside, and finally bolt it by using a M6 flange type bolt. If done neatly, you want see any rubber strap.
Is there a reinforcement washer on the inside of the broken piece..?..probably yes..
Can draw you a pic if needed...
09-28-2020, 11:47 PM
Threads: 36
(09-28-2020, 11:47 PM)peterbaron_imp Wrote: This probably broke due to vibration and skinny end design, which cannot absorb vibration and weight of the chain guard.
No reinforcing washer, just a hole in the metal.
09-29-2020, 12:01 AM
Houtman_imp Offline
Threads: 115
I might not look great but you could clamp the guard between two washers and use a longer bolt.
09-29-2020, 12:45 AM
How about gluing the PLOT guard over the original guard and remount using the originals brackets? Not sure if it would slide over it, though.
09-29-2020, 12:50 AM
The A-man Offline
Western North Carolina
Threads: 9
Likes Received: 79 in 30 posts
Likes Given: 50
i think I'd have it welded, then just paint the tab in flat black to cover the discoloration. The black will just make the tab disappear.
09-29-2020, 02:15 AM
PowerDubs_imp Offline
Threads: 125
You can have my Plot for a burger and a couple beers....if you can find me a tasteful black or brushed aluminum I can buy to replace it.
I don't want plastic, and I don't want something with a logo etched into it.
The Plot looked great when I had standard black steps- but not so much with my brushed aluminum steps now.
09-29-2020, 05:01 AM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 2 480 04-14-2025, 05:16 PM
Last Post: deuce17EX
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 11 1,001 04-11-2025, 02:41 PM
Last Post: rdprdp01
   Tank Guard Options Yata-Garasu_imp 11 747 05-18-2022, 08:11 AM
  Front Fender Splash Guard Wagonpeddler_imp 26 1,692 03-03-2022, 05:45 PM
Last Post: jtopiso_imp
  Brake lever guard for track days mrded_imp 17 1,306 05-26-2021, 07:50 PM
Last Post: mrded_imp
  we know this engine guard ? alprider 1 320 06-27-2020, 07:32 AM
  Oil Cooler Guard Chris Goldson_imp 10 951 11-09-2017, 11:41 AM
Last Post: Dvassino_imp
  SW-MOTECH Engine Guard 17-CB-002 4 490 08-03-2017, 07:13 PM
Last Post: Rocky_imp
  Engine Guard ajacobspilot_imp 3 373 04-10-2017, 10:11 PM
Last Post: Obleo
  Cee Bailey Headlight Guard - CB1100 venturer434_imp 2 344 01-23-2017, 02:44 AM
Last Post: venturer434_imp
