Type II handlebar alert
jimilivz_imp Offline
Threads: 2
Just tried installing the type II bars on my 14 std. Unfortunately the drilled locator holes for the switch housings were nowhere close to where they need to be. About 45 degrees off. If I installed the switches in the holes provided, they would be rotated forward by that amount. Obviously unusable.
Anyway, I purchased them this week from samurider, Honda part #53100-mgc-930. Don't really want to send them back to Japan. Anyone have any thoughts?
08-30-2014, 06:31 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Received: 34 in 20 posts
Likes Given: 116
RE: Type II handlebar alert
Re-drill the locator holes.
08-30-2014, 07:01 AM
Threads: 2
Have no desire to do any drilling. I was under the impression that they were a direct replacement. Plus, they are only about an inch lower, and inch narrower in width, same sweep. Not worth the trouble imho.
08-30-2014, 07:28 AM
HikerToo_imp Offline
Threads: 114
I wonder if they are OK on the 2013, I have not heard of this problem before......
08-30-2014, 11:14 AM
Likes Given: 596
I had to drill my bars when I put the 13 switch in my 14. I think they'd probably fit a 13 just fine.
08-30-2014, 11:16 AM
grover_imp Offline
Threads: 6
(08-30-2014, 11:14 AM)HikerToo_imp Wrote: I wonder if they are OK on the 2013, I have not heard of this problem before......
They're a 1:1 straight forward swap on the '13, at least mine was...
08-30-2014, 11:17 AM
INTP_imp Offline
Threads: 10
Mine too.
08-30-2014, 11:18 AM
Threads: 114
OK, good, and a 1" drop is OK with me, did not want to make too drastic of a change.....mine are on their way. would have ben nice to order these fro OP for discount ;-(
08-30-2014, 11:19 AM
Capo Offline
Sea Girt, New Jersey
Threads: 51
They fit perfectly on the '13, and I believe the difference in dimensions are a bit more than you've described. They make a noticeable difference once installed. May be worth drilling, just put them in a vice, get the right bit, easy. Otherwise I'm sure someone here with a '13 will buy them from you. I love my type 2's!
08-30-2014, 11:36 AM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 231 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,226 08-07-2025, 05:24 AM
  Tires ~ Converting tube to tubeless type. 17-CB-002 29 1,478 02-18-2024, 06:15 AM
Last Post: Venteuri_imp
  Tube type/size KubaGrom_imp 12 690 02-27-2023, 02:44 PM
Last Post: Mafd2_imp
  Handlebar Risers?? bubblerboy64_imp 16 1,078 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 497 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 399 04-03-2022, 01:00 AM
  Handlebar from 919 motorider6_imp 10 665 05-27-2021, 12:47 PM
Last Post: Stichill_imp
  CRF1000 handlebar mspaansnl_imp 0 169 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 32 1,643 01-20-2021, 10:42 PM
