Road Comet Install.
SeaFlea_imp Offline
Threads: 3
Road Comet Install.
Greetings all, I need to ask those folks that have already installed a Road Comet bullet cowl on a 2013 CB1100. I'm having trouble understanding the single fastener drawing that come with the unit. I can't get the bottom fastener to line up with the cowl. I've replaced the headlamp screws with the supplied ones and I think I've got the bottom center fastener bracket installed right. I've installed the "L" bracket on the dual horn center screw. It's a "dome" nut on a stud. It seems the cowl sits about an inch forward of the mounting hole on the "L" bracket.
Can anyone help or has anyone found a real set of installation instructions.
Thanks to all for your time.
SeaFlea, Stuck in Memphis.
10-30-2014, 08:32 PM
ClassicVW_imp Offline
Threads: 6
RE: Road Comet Install.
If you already tightened the headlight bolts, there's your problem. If you loosen, but not remove, the headlight bolts, can't you then pivot the cowl "down" to where the hole lines up with the bracket? Loosely fit everything together, THEN tighten everything. Don't overtighten the lower bolt and nut.
And the top of the L bracket is facing forward, right?
10-30-2014, 10:43 PM
SeaFlea_imp Offline
Threads: 3
VW, The bolts holding the headlamp are tight but the screws that hold the faring are loose. Maybe I need to loosen them more and see how it fits.
I mounted the "L" bracket where the captive nut is facing up to recieve the fastener that goes thru the cowl from the bottom. I'm fairly sure thats right.
Thanks for the reply. I'll work it again this evening.
SeaFlea.
10-30-2014, 11:56 PM
Southpaw50_imp Offline
Threads: 4
(10-30-2014, 08:32 PM)SeaFlea_imp Wrote: Greetings all, I need to ask those folks that have already installed a Road Comet bullet cowl on a 2013 CB1100. I'm having trouble understanding the single fastener drawing that come with the unit. I can't get the bottom fastener to line up with the cowl. I've replaced the headlamp screws with the supplied ones and I think I've got the bottom center fastener bracket installed right. I've installed the "L" bracket on the dual horn center screw. It's a "dome" nut on a stud. It seems the cowl sits about an inch forward of the mounting hole on the "L" bracket.
Same thing happened to me when I installed mine. After attempting every possible way to install it, I came to the conclusion the L bracket was the wrong one. Went to Home Depot and bought a longer bracket. Simple fix.
10-31-2014, 08:13 AM
SeaFlea_imp Offline
Threads: 3
Installed. I loosened everything and was able to get it seated correctly.
thanks to all for your replies.
Good Rides, SeaFlea.
11-10-2014, 06:19 AM
  power port and Samurider Road Comet Fairing 1 tdbru 9 971 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 962 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 973 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,129 01-22-2023, 03:07 AM
  Road Comet Fairing Catbird_imp 47 4,069 08-16-2022, 10:33 PM
   Road comet 2 fitment correct?? gretle_2.0 8 798 05-07-2022, 11:08 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,028 04-08-2022, 09:28 PM
  Windjammer ss. Install caddy425_imp 15 1,197 03-29-2022, 01:28 PM
Last Post: Canadianredneck_imp
  Puig Plus install question Rolls_imp 16 1,237 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,197 01-05-2022, 10:54 PM
Last Post: Nibis_imp
