 Road comet 2 fitment correct??
gretle_2.0 Offline
PA
Threads: 14
Hello guys, I recent got the road comet 2 and installed following all the correct steps but it seems like the light comes through the top and doesn’t fit up completely perfect? Is this how it’s supposed to look?
05-07-2022, 09:13 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
Is it possible the headlamp is aimed too far up since you had to remove the bolts to install the fairing?
I do not have the comet but I have the Emgo Venom ll that is the same design and I dont believe i have that issue anymore.
When I was using the Puig Universal and Puig Raptor windscreens they were a little forward of the headlamp like your problem now and at night the headlamp would refract off the inside of the windscreen and effected my night vision and I HATED it.
Thats why I eventually went with the Emgo Venom ll (couldn't afford the comets) and added auxilary lights to my engine guards.
Unfortunately I have not been able to ride the motorcycle since I did those upgrades last year but my brother and friend have taken it out for me and said there was no issue with the headlight lighting up the inside of the fairing and also said there was no issue with wind.
I will go in the garage now and see if I can get a photo for you of the fitment
Again this is not the comet but basically a knock off (if you want to call it that) and fitment looks nearly identical to your photos.
Hopefully someone with a comet can help further[Image: 9cbf39df359a4b100ba29eb137e3d622.jpg][Image: 6df4ccb795488e1fdf7820d6bf6ee2f8.jpg][Image: a119359ca845a8a3b1c2acff42750396.jpg][Image: 501f85d6707eb0a32049e65af13d2cf1.jpg]
05-07-2022, 09:28 AM
gretle_2.0 Offline
PA
Threads: 14
RE: Road comet 2 fitment correct??
(05-07-2022, 09:28 AM)mvk24_imp Wrote: Is it possible the headlamp is aimed too far up since you had to remove the bolts to install the fairing?
Yeah I guess that makes sense, I’ll have to look at it tomorrow again and try to fix it. Thank you for the photos!
05-07-2022, 09:31 AM
mvk24_imp Offline
Threads: 18
Yeah I guess that makes sense, I’ll have to look at it tomorrow again and try to fix it. Thank you for the photos! Yea maybe loosen up the bolts slightly and see if you can get a little play in adjusting the fairing.
Mine has about a 1 inch slot in each side for the mounting bolts so I have a little bit of adjustment forward and backward to get it to fit right.
You look like you have a little more space on the bottom of your light and I have a little more space on top so it might just me that your lamp is aimed a little too high after doing the installation.
05-07-2022, 09:39 AM
gretle_2.0 Offline
PA
Threads: 14
Yeah I think your right,I’ll try that tomorrow. Thanks again!
05-07-2022, 10:06 AM
mvk24_imp Offline
Threads: 18
Yeah I think your right,I’ll try that tomorrow. Thanks again! No problem, report back I'm interested to see how it goes!
05-07-2022, 10:08 AM
Frulk_imp Offline
Threads: 108
It looks like your headlight is tilted up somewhat as that gap is larger than the one I have between the light bezel and my Road Comet. I never ride at night so I wasn’t sure how much light came through so I just went out and checked in the garage. Turned bike on. Very little light actually gets through. Certainly not enough to bother me.
05-07-2022, 01:58 PM
The A-man Offline
Western North Carolina
Threads: 9
Likes Received: 79 in 30 posts
Likes Given: 50
I recall a thread on here somewhere where guys used a small piece of weather stripping to block that light spillage. Mine has some, but I never ride at night.
05-07-2022, 08:20 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Yes A-man, there is a How to thread on the light leak. It is a tad involved but I did mine a lot easier with a piece of thin rubber strip (mine is an RC1). Easy.
Having said that, the RC2 was supposed to take care of the problem, but whatever, easily fixed if still a problem.
05-07-2022, 11:08 PM
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,028 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 1,069 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 1,077 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,284 01-22-2023, 03:07 AM
  Road Comet Fairing Catbird_imp 47 4,552 08-16-2022, 10:33 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,130 04-08-2022, 09:28 PM
  Road Comet 2 Impressions Frulk_imp 12 958 11-14-2021, 07:09 PM
Last Post: mrded_imp
  road comet fairing vfrpaul98_imp 75 5,374 10-21-2021, 02:41 AM
   Saturday morning project - Road Comet 2 Fairing LuckyNLife_imp 11 951 09-16-2019, 11:36 PM
Last Post: Cobalt23_imp
  Road Comet II: Puig Clip-on Visor? Townie_imp 5 490 08-10-2019, 05:16 AM
Last Post: warman_imp
