Tools you'll need
#61
I'm putting this in here, but also starting a separate thread. The CB 1100 takes special one off spark plugs designed for this bike. made by NGK they carry the designation LMAR8A-9S Honda part number 31908-MGC-003 and takes QTY 4. The bodies on these plugs are extremely thin as are the threads which are also extremely long at 26.5 MM or just over an inch.
The plugs are expensive at $19.99 each and it's highly unlikely your dealer will stock any so they will probably need to be ordered. A standard spark plug wrench is not going to work well given the small confines of the area to work in. However Motion Pro makes a thin walled 14MM narrow plug wrench that uses a 1/4" ratchet, a 13 mm box end wrench or a 14 mm box end wrench socket or T handle to loosen and tighten. It also has a rubber ceramic gripper up inside. Your dealer can get this from one of his suppliers or you can order it directly from Motion Pro (thanks to HondaJon post #35 for the tip)
This pic illustrates just how small these plugs and tool are, On the left is a standard spark plug socket next to the Motion Pro Unit.
On the right is a standard spark plug next to the plug used in the CB 1100. Gap .031-.035 using a wire type feeler gauge is recommended.
[url=http://smg.photobucket.com/user/theferret111/media/image.jpg1_zpsakibhpti.jpg.html][Image: 1a366525cf4e95a368a7a7b1e7aedfad.jpg]
Like, good detail, hoping to learn something
Enlightening (is this even a word) thanks for the pic's Ferret, learn something new everyday....
Thanks for the spark plug socket tip Ferret. Just ordered one:
http://www.ebay.com/itm/291326886922
It's oil change time and I located an inexpensive "cap style" oil filter wrench at the local Walmart. It's a Fram #FM101, about $3.00. 65-67mm, 14 flutes. Snap it to your 3/8" extension and ratchet and you're good to go.
Edit: This wrench fits the OEM filter perfectly. I don't claim that it will fit any aftermarket filters.
(01-28-2014, 03:01 AM)redbirds_imp Wrote: Thanks for listing the tool selection, very handy especially for making my take along tool roll. For me, a lift is essential kit for home bike maintenance and Harbor Freight's lift is hard to beat for the price. Be sure to get the HF front wheel chock also as the one supplied for the lift is not the best.
[Image: a402ed7e73f1bb47e52b64090be583aa.jpg]
(06-12-2013, 08:40 AM)The ferret_imp Wrote:
(06-11-2013, 06:31 AM)meowguy_imp Wrote: A great thread and thanks to the ferret for giving us this.
One thing I am a stickler on is the proverbial torque wrench. You really need to include two of them in your list. You will need one that goes from from 0 to 250 inch pounds and another to take you up to at least 80 foot pounds. That's a nice looking 32mm above, but what's missing?
You just cannot do the job properly without knowing you are torqued correctly.
Geez on nearly every motorcycle board there is a big argumentative thread about the merits and demerits of using torque wrenches. most everyone will agree that when rebuilding a motor, a torque wrench is required. There is never an agreement on the value of torquing dry threads vs wet threads, or whether the value assigned by the engineers is even reasonable in many cases. Oil drain bolts, oil filters, and rear axle nuts come to mind. Torque some oil filters to spec and you may never get them off again. Many seemingly experienced wrenches will regal horror stories of stripped nuts and bolts when bolts are torqued to spec with a torque wrench.
My advice is use a torque wrench if it makes you more comfortable and use feel it that makes you more comfortable. To each his own. I own two like yoou advise. Sometimes I use em, some times I don't. Haven't stripped anything and nothing has fallen off so Im comfortable both ways.
I second that. An improperly calibrated torque wrench can cause some real problems and torquing oil filters to the manufacturer's specs is a sure way of not being able to remove it next oil change. I've always hand tightened oil filters and have never had one leak. If you torque the oil drain plug be very careful that your wrench is calibrated and always use a new sealing washer. Over-tightened drain plugs can mean a cracked oil pan as aluminum is not as forgiving as steel. Please don't ask how I know this.
So Redbirds,really dig the picture of your living room with the 2 bikes and the mc lift in it.How'd you talk your wife into that?Thumbs Up
Can one of you tell me what tools came with your bike? I'm wondering if I am missing something. All I got was a screw driver, a fuse puller and an allen wrench.
Thanks in advance.
And that's all you get in the US.
You can buy the rest though.
(07-11-2016, 01:05 AM)Lord Popgun_imp Wrote: And that's all you get in the US.
At least they put them in a plastic bag, LMAO
Luckily for me I have a good selection of tools in my shop. Also have a killer lift that came out of the Harley factory in York PA. I use it primarily to work on Garden tractors, my other hobby.
Or just make one up from what you have... Smile
Man, your CB looks a lot different than mine Wink
  OBD Tools Davidjill_imp 9 788 11-16-2024, 02:00 AM
Last Post: Whoops
  Tools Explained... Bazbro_imp 12 868 11-19-2021, 03:26 AM
  Tools dave 22 1,469 03-17-2021, 01:56 AM
  Mandatory Tools for Road Trip (2017 model and later) 17-CB-002 35 2,627 10-29-2020, 12:03 PM
