2017 cb1100
#61
Changing the rear wheel on the shaft drive can be so easy. Probably the best argument for shaft; and I've had both standard swing arm and single sided swing arm shaft drives. Although the singe sided did not have a center stand and I had to go with an after market stand for shop use.
Thanks for bringing that point up Masked One, that is a very good one.
(02-12-2016, 09:21 AM)spacetiger_imp Wrote:
(02-11-2016, 06:49 AM)Inhouse Bob_imp Wrote: Ginger was hot.
That is because she had a fever...
Mary Ann on the other hand has the really good looking bomb shell of the show. We all knew we had a chance to get a date with the girl from Kansas, not from Hollywood.
Tongue
Tongue
Speak for yourself, hayseed. I was a very high-reaching kid TongueTongue
Yesterday there was the big classic bike event, (mostly parts of classic bikes) I went they hold twice a year, once in February and once in October.
Yesterday Triumph showcased their retro models...dealer there said they Scrambler will be the last aircooled they sell because of the Euro emission rules...
So it seems the CB1100 and Yamaha XJR are the last air cooled bikes sold new?
Anyhow, I wanted to share this.
The older Bonneville model converted to a belt drive system! Thumbs Up
I actually think it looks rather good on the bike.
That bike was also modified with other aftermarket parts and looked sweet as heck,
6 piston front brake caliper, and look at those Alpina spoke wheels.
[url=https://picoolio.net/image/IdMs][Image: 0fd6335acc3413c43c68a6d8b4ea4105.jpg]
[url=https://picoolio.net/image/IdMy][Image: 5fe329579c0cdbacc47710afd3f3d78a.jpg]
[url=https://picoolio.net/image/IdM0][Image: 3931e58ac3db4d824d0325b3dfecbf46.jpg]
If the offered a similar belt drive system for our CB's I'd be tempted.
The Scrambler was also a beauty! Cool
[url=https://picoolio.net/image/IdMR][Image: 10a904f5777cae6ef855b746733154be.jpg]
[url=https://picoolio.net/image/IdMo][Image: 9407f1e0b847a4dfe34f709f675f9479.jpg]
When looking at both air cooled twin cilinder engines, I noticed how 'think' the fins were and realised I was saying to myself: nothing beats the good 'old' 4 cilinder from Big Red Cool
I didnt like the look of the new and very powerful Thruxton at all.
And the tank of the underpowered Street Twin look so tiny, I had to laugh thinking it was made for children.
While the new retro Triumphs meet emission rules and have all kinds of high tech gadgets, purely on the looks department they went a big step back, imo.
At the risk of opening a can of worms, I'd suggest that all bikes are air-cooled, even if they're full of coolant and have a water pump and radiator. Without air flowing through the radiator, the engine would overheat. Semantics, I guess.
Ducking for cover...
Not to defend the new Street Twin, but the gas tank holds 3.2 gallons and the bike reportedly gets 70 mpg. That's a similar range as the CB.
That belt conversion is really cool. I always got put off by them because I immediately think of having the giant belt and tensioner system like a Harley (which looks good on such a big bike), but this actually doesn't look at all put of place on a smaller bike.
don't you need specialized equipment to set the tension on a belt drive? (That's what the dealer told me when I bought my 94 Sporty)
(02-15-2016, 07:43 AM)The ferret_imp Wrote: don't you need specialized equipment to set the tension on a belt drive? (That's what the dealer told me when I bought my 94 Sporty)
Just a belt tension gauge, much like the ones used to test/set tension on automotive belts. About the only time you'll use it is after the back wheel has been off. Belts generally don't need periodic tension adjustments like chains. Your rear tire will wear out long before the belt needs adjustment.
Back when I was a collector of Kaw 750 twins, I used to work on my buddy's rare '83 belt drive model. I was amazed at how well the belt held up. Last time I saw it, it was 15 yrs. old with about 60k miles and still on the original belt.
A belt drive on any bike with more than a few inches of rear suspension travel would do best with a spring tension pulley I think as the Buell had. That would eliminate the need for any special tension set tool and would make it possible to fix the rear axle position
(02-07-2016, 11:13 AM)The ferret_imp Wrote: 650 Nighthawk, 700S Nighthawk, CB900 Custom, CB1000Custom, Yamaha 650 Maxim, Yamaha 650 Seca, Suzuki GS850, GS1000G, GS1100 to name a few.... the Japanese figured out how to put a driveshaft on an I-4 at least 30 years ago no problem
First drive shaft on a Kawasaki was the KZ1000E1 in 1979. They still use many if not most of the components. Turning crank power is done with 45 degree gears called bevel gears. They almost NEVER wear out; only maintenance are seals which are kind of a pain and something you would normally have a shop do. I have the tools to do Kaw shaft seals. This is a pic of a 79 KZ1000E shafty I rebuilt from the ground up...
Beautiful George. One of my favorite Kawasakis.
  CB1100 EX 2017 -Fork oil level Neo_imp 4 584 04-29-2025, 03:44 PM
  What is the fork oil level for a Honda CB1100 RS 2017? motorducquangngai_imp 1 312 10-03-2024, 01:36 AM
  Service Manual 61MGC02 2013-2017 CB1100 available sleeper_imp 6 717 11-04-2022, 01:37 AM
  RE: 2017 CB1100 Owners Registry Silas_imp 87 7,025 12-06-2021, 03:49 PM
Last Post: jerrycon_imp
  New Owner of a 2017 CB1100 EX Kalamari_imp 22 3,143 11-18-2021, 03:03 AM
Last Post: Whoops
  Looking to buy a 2017 CB1100 EX... what should I pay? Morocco36_imp 15 1,239 01-06-2020, 09:47 AM
Last Post: mustang462002_imp
  Rubber dampers for the 2017 CB1100 EX's front rotors VLJ_imp 14 1,524 06-21-2019, 11:56 PM
Last Post: 17-CB-002
  2017 CB1100 EX Headlight omarj_imp 19 1,378 03-19-2019, 09:28 AM
Last Post: DBM_imp
  2017 CB1100 - Just some random wintertime thoughts ohiorider_imp 22 1,652 03-13-2019, 02:06 AM
Last Post: VLJ_imp
  2014 CB1100 Std vs 2017 CB1100 ?? ohiorider_imp 14 1,260 12-22-2018, 10:49 AM
