FOBO tire pressure monitoring system report..
Chuckk_imp Offline
Threads: 19
RE: FOBO tire pressure monitoring system report..
#51
. I'm thinking, based on the refresh rate my phone receives, it sends out periodic.. I have waited 30 seconds or so at times to get a response on my phone's fobo display when filling my tires.. so what happens when the phone connects with the sensor? what happens to the sensors battery consumption? does it go up ? thanks for the input G.O.
03-06-2020, 12:06 PM
#52
I don't know the underlying implementation, however, each wireless message transaction costs the device some battery capacity. The more frequent, the more energy consumed. Device listening (if applicable) is not so expensive in terms of power, but when it sends out data, your button battery (s) take a hit.
During connection establishment between the phone and the device, there is an exchange of information. I am assuming the link is probably not encrypted (i.e. nothing secret about tire pressure), so device power consumption should be minimal.
Maybe the FOBO communication is just one way? Would you happen to know if you can configure anything inside the FOBO from within your phone app? Would you know if the devices are Bluetooth enabled?
03-06-2020, 12:31 PM
Chuckk_imp Offline
Threads: 19
#53
tough questions fo me to answer G.O. .. it seems there must be a back and forth.. between sensor and app.. when that happens, more power is used from the sensor.. thats the only thing I can think of that would cause the 3 month lifespan of the sensors battery.. unless I had a sour battery in my front wheel !! .. in the past, when my app allowed me to use the "only when app is turned on" my batteries lasted 7 months if I recall .. back then, they weren't able to talk to each other when I was close to the bike.. (100 ft) I'm guessing.. now the fobo2 app has more features.. that might play a part.. Confused gps is on it now, but that would come from my phone's battery .. I have another email that should be answered tonight.. we will see what Hazwan has to say.. unfortunately I am not asking the right questions.. now my hopes are for a sour battery.. we will see how long my rear sensor lasts..
03-06-2020, 01:00 PM
#54
It is definitely possible one button battery can be substandard. I have had that a few times.
03-06-2020, 01:05 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
#55
GO, the FOBO site says it is Bluetooth 5.0. Here is a link to the FOBO Bike 2 model: https://my-fobo.com/Product/FM2410
03-06-2020, 07:35 PM
#56
Right on popgun. So that means energy will be spent in two-way communications, and always listening, even if the paired phone is not around. Not a lot, but the radio will come on periodically. I suspect maybe Chuck had a weaker button battery? The other remote possibility is the one FOBO device has a bug in its firmware where at some point it got into a state for awhile (e.g. several hours) where it could not put its bluetooth radio into a power save mode. Just some guesses. Firmware bugs are quite common in consumer devices.
03-06-2020, 10:18 PM
Chuckk_imp Offline
Threads: 19
#57
thanks guys.. I really appreciate your input.. one more thing to consider is, I am using the original fobo sensors that came with my original fobo bike, as they call the first generation.. then I was told by mr. fobo, I can utilize the fobo 2 app and keep my original sensors.. so that is what I am running.. also, I do have another 2 or 3 original sensors that I had on my trike.. so if I have a faulty sensor, I could trade it out.. maybe wait and see how long my other sensor's battery lasts.. time isn't a problem.. mr. fobo didn't return yesterday's email Sad
the new fobo 2 sensors are smaller and are still supposed to last about a year.. they take smaller batteries..
03-07-2020, 02:30 AM
Chuckk_imp Offline
Threads: 19
#58
well, my FOBO battery problem has reared it's ugly head once more.. this time the battery lasted for less than a month !!.. G.O. suggested it may be a faulty sensor.. I have extras, so I will replace battery and sensor on the front.. the rear sensor is still happy with the battery I installed in it last December..
.[Image: d6126d0cd236eb7bce819e350eb4a3a0.jpg]
03-29-2020, 01:02 AM
peterbaron Offline
Likes Received: 575 in 312 posts
Likes Given: 957
#59
Not that I have a cure, ready answer for your problem or I question previous pre-diag by more experienced fellas in this matter...but a few things to consider:
* cheap or poorly design products usually draw more current or normality in your case
* your FOBOs constant communication with your cell means: slow and continuous discharge
* simply said: when the ambient temperature drops , the battery is able to last longer. When the temperature increases, the battery life shortens. I think, California climate delivers these two extremes almost daily, correct?
* before installing a new battery, check its voltage, as well when discarding it
* battery lifespan depends on its quality/manufacture + some other factors
* general rule is: if you buy 2 cheap, you pay twice for it = overpaid vs 1x good quality + no headache
** your FOBOs and batteries are constantly facing centrifugal force, spinning, shaky/twisty roads, brake pads dust falling on them, pistachio load/smell....so no wonder these wander, get brain damage and die prematurely Tongue
03-29-2020, 02:21 AM
Chuckk_imp Offline
Threads: 19
#60
I try to buy the best batteries..
.[Image: 6bb6330b59c900000e632bd9118ddb52.jpg]
you can buy a cheap T.P.M.S. for about $30. the FOBO's run about $100. .. the rear sensor is working fine so far, telling me it is either the battery or the sensor in the front..
03-29-2020, 02:27 AM
  Exhaust system/slip-on johnny_elpino_imp 26 2,057 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,608 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,742 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  DLX Exhaust System Conversion Ron in MO_imp 28 1,776 08-26-2021, 10:50 AM
Last Post: bvictory_imp
  hepco becker side back C system alexzanutto_imp 16 1,467 07-31-2021, 07:34 AM
  Smart Turn System ozigoo 6 575 05-30-2021, 10:59 AM
  QUAD LOCK IPHONE SYSTEM Alfgaxatico_imp 33 1,727 01-25-2021, 08:39 AM
  Arrow full system exhaust tsmetjen_imp 19 1,324 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
  Delkevic full system?? juliang_imp 4 438 07-29-2020, 05:50 AM
Last Post: Bheezy27403_imp
  Adding an oil pressure gauge wiscoaircraftmech_imp 7 531 06-30-2020, 01:41 AM
Last Post: wiscoaircraftmech_imp
