Delkevic full system??
juliang_imp Offline
New to the Forum
Threads: 1
I tried searching and only found muffler reviews. Has anyone tried one? How do they perform and how do they sound? Also how well are they made and do they hold up?
Thanks in advance.
05-04-2020, 10:21 AM
Bheezy27403_imp Offline
Threads: 39
RE: Delkevic full system??
I have a pipe of theirs and a few others do as well. From my experience they are well made.
m in sc has a full system I believe. He'll chime in soon enough.
05-06-2020, 12:59 AM
BrandonWeimerskir_imp Offline
New to the Forum
Threads: 0
love the sound and performance of mine. the stock pipes and tubes are very quite which isn't always bad but this Delkevic has a good balance. its not overbearing nice low rumble. Sounds amazing.
05-06-2020, 02:05 AM
Jd2ride Offline
USA
Threads: 1
Likes Received: 6 in 5 posts
Likes Given: 2
I have a full Delkevic too and agree with everything M in SC said.
The mid piece is a tad too short and it was a bit of a pita to get it sorted, in fact I called Delkevic USA for help, and finally made it work.
The easy way is to make an adapter as M in SC shows in his write up ( big thanks for that, it helped a lot) but Delkevic should correct it at the source. Otherwise, it's a really nice pipe, looks and runs great once it's on.
If you've never installed a header before, especially one that's all separate pieces, get some help cause it's tricky. I'm definitely not a novice at this and it was a challenge.
When I ordered the pipe, I got the 18" oval stainless can. However, it's still in the box.
I instead used the 13" Delk stainless tri-oval slip on I already had. Running without the db killer and it sounds just right to me. Not too loud, just a lot of deep rumble at lower revs. Higher up it gets louder, but sounds good to me. YMMV.
I have the O2 sensor delete dongle, intake mod, pair valve blocked in the airbox and a Booster Plug for the fuel injection. It runs great, sounds mean and I get lots of compliments about it. I'm happy with it.
05-09-2020, 06:49 AM
Threads: 39
How about a report on the system after some mileage? I'm assuming they go gold/brown? Are they freckled like the stockers? Pics please?
07-29-2020, 05:50 AM
  Help with Delkevic 4 into 1 inditx_imp 2 404 11-09-2024, 02:50 AM
Last Post: inditx_imp
  Exhaust system/slip-on johnny_elpino_imp 26 2,370 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 4,214 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,980 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  PCV with full exhaust worth getting tune?? gretle_2.0 4 489 05-24-2022, 03:43 AM
Last Post: gretle_2.0
  Arrow full exhaust gretle_2.0 2 372 05-17-2022, 11:38 AM
  Moriwaki 4 into 1 full pipe GS1100_imp 9 785 01-30-2022, 12:59 PM
Last Post: rich_imp
  full delkevic exhaust outback_imp 27 2,327 01-14-2022, 11:12 AM
  DLX Exhaust System Conversion Ron in MO_imp 28 2,206 08-26-2021, 10:50 AM
Last Post: bvictory_imp
  hepco becker side back C system alexzanutto_imp 16 1,669 07-31-2021, 07:34 AM
